weird noise from one of the drivebelt pully??
Old Apr 17, 2008 | 09:18 AM
chokin's Avatar
I'm back
as title says. my car has 80,000 miles, and lately i can hear a " e-e-e-e" noise coming from the right side of the engine bay, especially when the car is in "drive" mode and at stop, it getting annoying, and when once i take off, canhear something like loose but then it will go away . So then i turned on my A/c, the "e-e-e" sound got louder. so i guess the noise may from one of the pulley or from the A/c pulley? or something else??? Anyone one has any soultion...would spraying WD-40 work?
thanks1!!
Old Apr 17, 2008 | 09:36 AM
SSCOUTURE's Avatar
I Had The Same Noise, It Comes From The Small Pulley Mounted On Bushings, I Sprayed Some Oil Inside The Bushing And It Stopped.
The Engine Also Felt Smoother.
Old Apr 17, 2008 | 11:42 AM
chokin's Avatar
I'm back
which one is it sorry ??? and wat kinda oil did u spray ? WD-40?
Old Apr 17, 2008 | 01:14 PM
SSCOUTURE's Avatar
it's the pulley just beneath the alternator, it's about 2 in. diameter.
you need to get some lube in there. wd-40 is too liquid and wont stick,
you need some liquid oil or oil film that will stick on there.
i don't have the brand but an oil film spray should do it.
Old Apr 17, 2008 | 01:57 PM
gogozy's Avatar
probably not oil.. i thought oil is bad for the belt? to check if it's belt making noise, spill little bit of water on the belt. if the noise goes away then you can put some wax on the belt later, or check the auto tensioner for the proper range. you may need to replace the belt...
Old Apr 17, 2008 | 05:30 PM
chokin's Avatar
I'm back
my belt range is between the square or retangle shape that went inside, not the pop up one tho.
Old Apr 21, 2008 | 10:48 AM
gogozy's Avatar
there are some thread about this, here is one.
https://acurazine.com/forums/showthr...highlight=belt
mine was making noise last winter so we put some wax on it and it went away for 100km then came back. but now it's warmer and i have not hear it in the past 2 month. But my tsx have only 55k km on it, 80K miles sound a lot to me!!
Old Apr 21, 2008 | 09:02 PM
chokin's Avatar
I'm back
i spraied some lube on the the pulley , the nosie seems went away amd my drivebelt is still in range as from the .pdf
ha 80k miles, yea i drove at least 60 miles a day because my gf lives like 30 miles away, so that how i got all my mileage from
MrHeeltoe
20
Feb 23, 2023 01:54 PM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
