water in intake going to motor
i got stuck in a flood and my cold air intake is close to the ground so it sucked up most of the water into the water. so there is water in the exaust manfold ....what should i do to get the car running again ..plz help me
, and the car is not flood damaged....(but considering that the motor probabaly stopped running; the water just came up the exhaust pipe); OR you basically HYDROLOCKED the motor, and probably just F@CKED it
either way to TRY and get it running again if no damaged has occured, is pull ALL the plugs out, and crank it, to clear out the cylinders, then toss them back in (might not hurt to toss in some new ones either, since they are out already), also don't forget to change the oil also, since water is probably mixed in there also (along with all the other fluids too)
remove your throttle body and use a wet-vac to get any sitting water out. Spray carb or brake cleaner all over the inside and let it dry out. Repeat until it looks dry. Pull your plugs, try to start the car for like 15 seconds with the plugs out, then spray some cleaner in there as well. Install new plugs. Change the oil and filter.
see if it runs. if it does and there's no weird noises or smoke you're probably good. if it runs without noises but smokes you blew your head gasket due to higher cylinder pressures caused by the water. If no noise or smoke, remove radiator cap and double check no bubbles coming out while running.
Jul 16, 2017 07:33 AM
rcs86
Aug 2, 2016 06:52 PM
STL TL-S
Sep 23, 2015 08:52 PM
