VSA ! - Light stays on
Old Jun 4, 2007 | 06:10 PM
SPARKIE's Avatar
The light goes off when I shut the ignition off and then restart but comes back on as soon as I push the brake pedal with the handbrake released.
Checked the fuses, brake fluid and all connections to ABS unit. The Check engine light did not come on but I still checked the ECU for codes and it was clear.
Anyone had this problem?
I'm out of warranty.
Old Jun 4, 2007 | 06:13 PM
godfather2's Avatar
Time to Climb
auto or manual?
Old Jun 4, 2007 | 06:17 PM
bz268's Avatar
Because Of You
Just a guess...
jack up the car and try to turn the wheels to see if the wheels turn freely. maybe the brake caliber is stuck.
I have seen a guy driving an old car with the brake stuck in one wheel. The guy left a tire mark miles long on the road.
Old Jun 4, 2007 | 06:21 PM
SPARKIE's Avatar
Originally Posted by godfather2
auto or manual?
Manual....how does that matter?
SPARKIE's Avatar
Originally Posted by bz268
Just a guess...
Def not the problem.
Old Jun 4, 2007 | 07:41 PM
poltergeist's Avatar
You might check to make sure the brake pedal position switch is functioning. With an A/T it's easy to know because the car won't come out of park. With an M/T you'll need to have someone step on the brake pedal while you watch to see if the brake lights come on. The switches have a fairly high failure rate in some Hondas. I've seen a dead brake pedal switch kick a VSA/ABS light before. Otherwise, you'll need to pull a code to see what might be causing a failure.
Old Jun 4, 2007 | 11:55 PM
aaronng's Avatar
Driver/Detailer
Probably a wheel speed sensor is malfunctioning.
Old Jun 5, 2007 | 07:32 AM
SPARKIE's Avatar
I don't think this is the cause since I can drive without the light coming on ...until I push the brakes. I'm thinking it's a ABS brake controller issue???
Old Jun 5, 2007 | 10:29 AM
Mskierki's Avatar
How is your brake fluid level? If the fluid level drops too much there would not be enough fluid to charge the accumulator used to power the brakes. This can also manifest itself with an abs light also. If this is the case and you don't have a leak it is probably time for new brakes.
I used to have that problem with my '94 Legend.
Old Jun 10, 2007 | 07:53 AM
SPARKIE's Avatar
Problem solved. .....The other day I hit my lock button twice to ensure the alarm was set and the horn did not sound. I then tried the horn itself and it did'nt work either. I wondered if the two problems were related ???? I then checked the horn fuse and found it blown and that it also protected the stoplight circuit. Tested and found a "dead-short " in the circuit and traced it back to the wiring connection in trunk for the dealer installed rear spoiler. The wire connections had been stuffed into the trunck mount arm and they must have got caught on the trunk lining/ trim and ripped the insulating tape from the connections leaving the bare wires to touch together causing the short.
I then fixed the connections, redressed the wires, replaced the 20 A fuse and everything now works and VSA ! light is out.
So I've been driving for almost a week without brake lights. The owners manual does'nt even mention that when the VSA ! light comes on that it could be brake light related.
Old Jun 10, 2007 | 10:14 AM
Old Jun 10, 2007 | 08:26 PM
aaronng's Avatar
Driver/Detailer
Very nice! Never knew that the VSA light comes on for brake light problems too.
Old Oct 17, 2013 | 10:16 AM
PoloShmolo's Avatar
Team Logik
have you checked your brakes? your brake pads?
Old Oct 17, 2013 | 10:08 PM
redpoint's Avatar
The problem was resolved 6 years ago. Worn brake pads shouldn't cause the VSA light to turn on.
Old Sep 3, 2014 | 04:05 AM
crzyg35driver's Avatar
vsa light
I have an 05 rl, vsa light comes on after i drive the car for a block or 2. Possible wheel sensor going out. How do i find out which 1?
mada51589
Jan 9, 2025 04:40 PM
cycdaniel
Dec 17, 2019 10:58 AM
hedzup
1G RL (1996-2004)
Jun 29, 2016 08:07 AM
Birdflunuggetz
ILX
Sep 14, 2015 07:00 AM
bryan zaragoza
Sep 8, 2015 12:28 AM
