VSA Light Blinking + Grinding
Old Sep 4, 2021 | 04:57 PM
Brodsky's Avatar
5th Gear
Exclamation VSA Light Blinking + Grinding
Hi all, I'll try to keep this short and simple...
I've owned my '06 TSX for just over a year now, and I've had this problem since I bought the car.
On two specific roads, both within a mile of each other, one being a downhill slope, the other being a flat highway on-ramp. Driving on these will 90% of the time trigger the VSA warning triangle to start blinking, and there will be a grinding noise under the pedals, which I guess is normal when VSA triggers. Continuing, there also seems to be a loss in input (throttle, braking, etc.), and the entire car feels "flimsy" for 1-3 seconds. There is never any loss of traction, and it almost never happens when I'm driving aggressively, but more often when I'm driving at or below the speed limit.
Occurs in all kinds of conditions regardless of if the roads are dry or wet, hot or cold outside, etc. Roads have been repaved during the year with no difference. Doesn't happen anywhere else. I am also not on the brakes or turning at all during these events.
My question is why it continuously activates ONLY on these two roads, never anywhere else, and what might be wrong with my TSX. A buddy of mine also has an '06 TSX, and has never had that happen to him, even driving on the same two roads constantly.
Thanks in advance.
Old Dec 15, 2021 | 12:33 PM
haniforama's Avatar
Are you using OEM tire size inflated to proper pressures? I would do a neutral position recalibration on your car.
huludicidal
May 2, 2010 02:55 PM
Goldenrod06
Jan 12, 2007 05:27 PM
Jeff The Pianist
May 7, 2006 02:55 PM
javierr
Jan 24, 2006 12:41 PM
Lung Fu Mo Shi
Oct 2, 2003 11:01 AM
