VSA and Check emissions light
Old Jul 9, 2011 | 08:14 PM
Acuragirl12's Avatar
Recently while I was driving the VSA check light and the emissions check light went on. The car also jerked forward as if about to stall. It is a 2006 automatic TSX. Now there is no power when the accelerator is stepped on the car will not rev up at all. The car also pops as if to stall when gears are changed. If the car is turned of for a couple seconds then turned on again, everything is fine for about 3 min of driving before the above occurs again. I have not taken it to the dealer as of yet, but will. In the meantime..... any idea's on what the problem may be?
Old Jul 9, 2011 | 08:25 PM
Moose Muscles's Avatar
If you have a scan gauge tool or some other obd2 scanner I would suggest getting the codes.
Or try your local autozone or oreilys to see if they can get the codes for you.
I have no clue what to suggest at this point, I just know those codes would give you (us) a direction to run with it.
Old Jul 9, 2011 | 08:31 PM
main70072's Avatar
Yeah, sounds like the car is in limp mode. Like Moose Muscles said, the code(s) from the check engine light should give a direction of where to start troubleshooting.
Old Jul 11, 2011 | 09:23 AM
Simba91102's Avatar
Old Guy
Good suggestions, but really kind of moot, don't you think? The car needs to go to a dealer or other shop ASAP since it sounds like it's basically undriveable.
Old Jul 11, 2011 | 11:05 AM
AznGuy's Avatar
5th Gear
you most have a timing chain that is not stretched as the same in my car, CEL and VSA light are on, how many km's and what year is your car?, scan your car and if you get P0341 its timing chains that need to be done
BlkTxAcuraTypeS
Oct 18, 2015 08:05 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
whitesoxsfan12
Sep 7, 2015 04:07 PM
