Buzzing Sound When Turn Key
Old Aug 1, 2010 | 02:01 PM
detch's Avatar
6th Gear
I have an '06 TSX and I have noticed a buzzing sound sometimes when I turn the key and sometimes when I turn it off. Is this telling me there is a starter issue? Any suggestions?
Old Aug 1, 2010 | 03:44 PM
curls's Avatar
Someone stole "My Garage"
I think it is the same thing I occasionally experience -- if so, it snot the starter, it might be the ignition switch or possibly the chip/transponder being a bit slow to sync up between key and ignition. I never experience it if I wait 0.5-1 second after inserting the key, before turning it.
Old Aug 4, 2010 | 10:50 AM
detch's Avatar
6th Gear
Thanks Curls. If I turn the key to the on position and wait a second, it doesn't make the sound, so it is probably the same thing you are experiencing. Thanks for the tip.
P.S. I also live in Ottawa
Old Aug 4, 2010 | 09:58 PM
curls's Avatar
Hey no prob!
Where do you live w/in Ottawa? I'm in Barrhaven.
Old Aug 4, 2010 | 11:02 PM
Miamicarfan's Avatar
This happened to me also.
My mechanic disconnected the battery ground wire where it is connected to the body of the car. He scraped both the wire connection and the part of the car where the wire is connected.
Problem gone.
Old Jun 8, 2011 | 01:01 PM
dominik331's Avatar
I have experienced this buzzing sound and has also noticed that if I push the key in and wait a second or two, it doesn't do it at all. I was also leaning towards the starter, as my battery is less than a year old and the alternator and the battery both tested ok.
Thanks for the tip.
Old Jul 11, 2011 | 03:18 PM
EvolveTSX's Avatar
Its the main relay buzzing. It does this if you dont turn the key quickly enough. Very common on 7th gen accords and the TSX. Honda says this is normal and is not an starter/ignition switch issue. Its happend a few times to me, and we've had customers come in complaining about this as well. Honda sent out a TSB/Shop Talk bulletin about the issue. You guys are good!
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
Iain MacLeod
Sep 17, 2015 01:01 PM
PortlandRL
Sep 14, 2015 12:01 PM
