VSA/ABS/Triangle Codes pulled
Old Jun 17, 2016 | 04:46 PM
Ck98vteC's Avatar
It came up with the following:
6-1 SRS code (I had dealer replace the drivers buckle)
11-1 speed sensor
61-1battery voltage malfunction (battery is 1 yr old)
83-1 ecm malfunction
I reset the ecu and see what comes back, but that was from today. Has anyone got any ideas?
Old Jun 20, 2016 | 09:41 AM
TexasHonda's Avatar
All codes are double digit w/ a suffix. All 61's are driver's seat belt
good luck
File Type: pdf
Old Jun 20, 2016 | 12:26 PM
Ck98vteC's Avatar
I had the driver seat belt buckle done, it used to bring the airbag light on. Someone else suggested the alternator may be going bad it will throw erratic codes like this.
Jbaum
2G RDX Problems & Fixes
Feb 20, 2024 07:27 PM
kooch20
1G RDX Problems & Fixes
18
Aug 15, 2021 02:37 PM
SuperGreg
Jun 10, 2016 08:02 PM
mattyacura
Jan 25, 2016 06:00 PM
