Vibrating steering wheel
I spend 2 much time here
Originally Posted by davo-cls
Warped rotors. Have the rotors resurfaced and I bet the vibration goes away.
actually since i first got them, shop i brought them to for balancing said one of the wheels was slightly bent out of shape so i replaced it, however that didn't fix the issue, so i had them rebalance all four wheels and still have the problem
Some reading for you jigga:
https://acurazine.com/forums/showthread.php?t=28908
https://acurazine.com/forums/showthread.php?t=23182
https://acurazine.com/forums/showthread.php?t=21174
Hope this helps.
Hope this helps.
Rep'n Taxbrain.com
Yeah, that's a tough one. You can put your OEMs back on and see if the vibration goes away. That way you can be 100% sure it's the tire/wheels.
If you have the hubcentric rings and proper balancing those are the big things though. Wish I had some other ideas.
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
I have the same issue... I took a ride w. my mechanic frined from Honda and he said some virbation can be caused by an uneven wear on tires.... or uneven road surface..... It will be a matter from balancing or allignment if the virbation is serious.
This issue has been beaten to death in this forum without one valid solution offered by any member. I have lived with this since getting the car, with colder weather making it more pronounced than on warmer days.
I'm pretty much at my fucking wit's end with regards to wanting to keep this piece of shit.
Have you tried the Hunter Road Force machine? I see jlukja mentioned that in an earlier post. You could have a slightly bent rim or a poorly matched rim and tire. The Hunter machine can correct for this. In simple terms no tire or rim is perfectly round. It could be that the "high" spot on the rim matches the "high" spot on the tire. If this were the case you would get a poor roll out. With the Hunter machine they can "force match" the rim and tire to correct for this. Good luck. I know how frustrating these vibrations can be...
Just dial 1911
1 Post
Originally Posted by jiggaman
how can i find out what shops use hunter road force machines in my area? i would like to try this method
Originally Posted by CGTSX2004
aka davo-tsx
Originally Posted by jlukja
![Yes](https://acurazine.com/forums/images/smilies/yes.gif)
![No](https://acurazine.com/forums/images/smilies/no.gif)
Sorry but
. My CL had this happen twice and it turned out to be warped rotors. They may be warped just enough to give off a vibration, but not enough to feel in the pedal yet.
![Scratch](https://acurazine.com/forums/images/smilies/scratch.gif)
aka davo-tsx
The vibration I had wasn't at all speeds, just maybe from 40-60 mph. It would be smooth, then the steering wheel would shake a little, then it would be smooth again once you got past a certain speed. The Acura dealer would look at it and say the rotors were warped again. They would get resurfaced and the vibration went away. Could it have been something else by coincidence....sure, but the CL's were notorious for warped rotors. Anybody that had one would agree to that.
SOLUTION
Hunter Road Force is the only machines i will have my wheels balanced on ever again. Brought my TSX to the local ford dealership because they have one of these machines and after running my wheels on this machine they determined that they were definately not balanced properly before and had too many weights put on and in the wrong locations.
End result is my car drives smooth as butter at all speeds and i am very pleased.
Only downside was that the knuckleheads did not mount my directional tires going the right way...This is after i warned the service advisor that i had directional tires. He assured me that they were pros and would know what to do! I made the mistake of trusting him and totally forgot to double check if they mounted them properly until later detail when i was washing my wheels. That is when i noticed the arrows going in the wrong direction. Oh well, i can live with that until i get around to switching them back.
thanks Jtso, definately goes to show that not all tools are created equally. what's even more sad is how many people spend money to have their wheels balanced everyday and are driving away with wheels that are not truly even balanced.
rockyboy
12-06-2022 02:29 PM
