Vibrating steering wheel
Old Sep 11, 2006 | 02:17 PM
jiggaman's Avatar
I spend 2 much time here
Ok i've had my wheels balanced twice now and i still get vibrations at highway speeds. thoughts?
Old Sep 11, 2006 | 02:26 PM
CGTSX2004's Avatar
Bent wheel? Bad bushing somewhere in the suspension?
Old Sep 11, 2006 | 02:27 PM
jiggaman's Avatar
bad bushing?
Old Sep 11, 2006 | 02:45 PM
drunkenbuda's Avatar
Got Phó?
something might be lose? Did you check all your bolts and nutz to see if its tight? Did you take it to your dealer yet?
Old Sep 11, 2006 | 02:51 PM
davo-cls's Avatar
aka davo-tsx
Warped rotors. Have the rotors resurfaced and I bet the vibration goes away.
Old Sep 11, 2006 | 03:01 PM
jiggaman's Avatar
if this were the case wouldnt the vibration only be present when i am braking?
Old Sep 11, 2006 | 03:41 PM
jlukja's Avatar
Old Sep 11, 2006 | 03:59 PM
jiggaman's Avatar
mine occurs at highway speeds and has nothing to do with hitting the brakes
Old Sep 11, 2006 | 04:49 PM
joerockt's Avatar
Just dial 1911
Hub rings...Got em?
Old Sep 11, 2006 | 04:57 PM
jiggaman's Avatar
hub rings..yes
Old Sep 11, 2006 | 04:58 PM
joerockt's Avatar
Just dial 1911
Are these the PIAA's? You've had them for a while now right? When did this start happening?
Old Sep 11, 2006 | 05:21 PM
jiggaman's Avatar
actually since i first got them, shop i brought them to for balancing said one of the wheels was slightly bent out of shape so i replaced it, however that didn't fix the issue, so i had them rebalance all four wheels and still have the problem
Old Sep 11, 2006 | 05:25 PM
ryanhook's Avatar
Slippy maybe...
Perhaps it's a flaw in the tires -- like belt separation? Though that's quite rare.
Just a thought.
Old Sep 11, 2006 | 05:30 PM
jlukja's Avatar
Some reading for you jigga:
https://acurazine.com/forums/showthread.php?t=28908
https://acurazine.com/forums/showthread.php?t=23182
https://acurazine.com/forums/showthread.php?t=21174
Hope this helps.
Old Sep 11, 2006 | 05:34 PM
Tsx536's Avatar
Rep'n Taxbrain.com
Yeah, that's a tough one. You can put your OEMs back on and see if the vibration goes away. That way you can be 100% sure it's the tire/wheels.
If you have the hubcentric rings and proper balancing those are the big things though. Wish I had some other ideas.
Old Sep 11, 2006 | 05:39 PM
jlukja's Avatar
Rotate the wheels front-to-back and see if it diminishes.
Old Sep 11, 2006 | 06:56 PM
Tumby's Avatar
I have the same issue... I took a ride w. my mechanic frined from Honda and he said some virbation can be caused by an uneven wear on tires.... or uneven road surface..... It will be a matter from balancing or allignment if the virbation is serious.
Old Sep 11, 2006 | 08:02 PM
TinkyWinky's Avatar
TSX User
This issue has been beaten to death in this forum without one valid solution offered by any member. I have lived with this since getting the car, with colder weather making it more pronounced than on warmer days.
I'm pretty much at my fucking wit's end with regards to wanting to keep this piece of shit.
Old Sep 11, 2006 | 08:21 PM
dug-mac's Avatar
Have you tried the Hunter Road Force machine? I see jlukja mentioned that in an earlier post. You could have a slightly bent rim or a poorly matched rim and tire. The Hunter machine can correct for this. In simple terms no tire or rim is perfectly round. It could be that the "high" spot on the rim matches the "high" spot on the tire. If this were the case you would get a poor roll out. With the Hunter machine they can "force match" the rim and tire to correct for this. Good luck. I know how frustrating these vibrations can be...
Old Sep 11, 2006 | 08:55 PM
jiggaman's Avatar
how can i find out what shops use hunter road force machines in my area? i would like to try this method
Old Sep 11, 2006 | 08:56 PM
joerockt's Avatar
Just dial 1911
Love it when you squirm. Are the walls closing in?
Old Sep 11, 2006 | 09:12 PM
TinkyWinky's Avatar
TSX User
No dumb-ass. Not yet.
Shouldn't you be out trying to outrun M35s with your POS?
Old Sep 11, 2006 | 09:16 PM
joerockt's Avatar
Just dial 1911
Awesome. Keep squirming fag.
Old Sep 12, 2006 | 07:59 AM
CGTSX2004's Avatar
http://www.gsp9700.com/pub/search/findgsp9700.
Old Sep 12, 2006 | 09:00 AM
jiggaman's Avatar
Originally Posted by CGTSX2004
thanks, found a local dealer and setup an appointment, time to get to the bottom of this!
Old Sep 12, 2006 | 10:58 AM
davo-cls's Avatar
aka davo-tsx
Originally Posted by jlukja
Sorry but . My CL had this happen twice and it turned out to be warped rotors. They may be warped just enough to give off a vibration, but not enough to feel in the pedal yet.
Old Sep 12, 2006 | 11:40 AM
jiggaman's Avatar
thanks davo, i will keep this in mind as well...
Old Sep 12, 2006 | 12:04 PM
jlukja's Avatar
How can a rotor be warped enough to vibrate the wheel yet not enough to be felt in the pedal? That doesn't make sense to me. You would feel a warped rotor in the pedal way before it would get bad enough to feel in the steering wheel.
Old Sep 12, 2006 | 12:35 PM
BzeTSX's Avatar
agreed
Old Sep 13, 2006 | 03:05 PM
davo-cls's Avatar
aka davo-tsx
The vibration I had wasn't at all speeds, just maybe from 40-60 mph. It would be smooth, then the steering wheel would shake a little, then it would be smooth again once you got past a certain speed. The Acura dealer would look at it and say the rotors were warped again. They would get resurfaced and the vibration went away. Could it have been something else by coincidence....sure, but the CL's were notorious for warped rotors. Anybody that had one would agree to that.
Old Sep 16, 2006 | 05:04 PM
jiggaman's Avatar
SOLUTION
Hunter Road Force is the only machines i will have my wheels balanced on ever again. Brought my TSX to the local ford dealership because they have one of these machines and after running my wheels on this machine they determined that they were definately not balanced properly before and had too many weights put on and in the wrong locations.
End result is my car drives smooth as butter at all speeds and i am very pleased.
Only downside was that the knuckleheads did not mount my directional tires going the right way...This is after i warned the service advisor that i had directional tires. He assured me that they were pros and would know what to do! I made the mistake of trusting him and totally forgot to double check if they mounted them properly until later detail when i was washing my wheels. That is when i noticed the arrows going in the wrong direction. Oh well, i can live with that until i get around to switching them back.
Old Sep 16, 2006 | 05:50 PM
JTso's Avatar
Congrats on solving the problem. I've always used road force balancing on all my cars.
Old Sep 16, 2006 | 05:52 PM
jiggaman's Avatar
thanks Jtso, definately goes to show that not all tools are created equally. what's even more sad is how many people spend money to have their wheels balanced everyday and are driving away with wheels that are not truly even balanced.
Old Sep 16, 2006 | 08:35 PM
CGTSX2004's Avatar
Glad to hear it got fixed, jigga. Road force balancing FTW!
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
04tler
Sep 10, 2015 04:03 PM
thisisnotdave
4G TL Problems & Fixes
Sep 8, 2015 10:02 AM
MyKids&Cars
Sep 2, 2015 12:03 AM
