Tsx electrical/starting problem
Old Nov 17, 2010 | 06:44 PM
fade06's Avatar
HI i have an 04 TSX and my problem is this, the other day i was driving in the rain and then my lights started to flicker, the radio and gps kept restarting and this happened more with my foot on the brake. once i turned the car off and tried to restart it died and needed to be jump started. Has this happened to anyone before?
Old Nov 17, 2010 | 08:24 PM
limeybstrd's Avatar
Weak battery or alternator. Have you had these tested?
Old Nov 17, 2010 | 08:36 PM
fade06's Avatar
i am gonna try to go to the auto store to get it tested, the one clse to me closed dow. thanks again
Old Nov 18, 2010 | 08:51 AM
fade06's Avatar
i was reading and i was wondering if this problem could be due to the bad ground battery cable
Old Nov 21, 2010 | 11:29 AM
limeybstrd's Avatar
Could also be that too.
Did you get your test done?
Old Nov 23, 2010 | 07:56 PM
fade06's Avatar
its weird when i wen tto autozone it said the alternator faile, then i went to the mechanic he said it passed his tests and nothing is wrong? he is as confused as i am.
Old Nov 23, 2010 | 09:28 PM
bluenorge's Avatar
i've seen this before if the battery clamps on the battery are loose or corroded. make sure those are clean and tight. make sure your battery is fully charged too.
Old Nov 23, 2010 | 11:09 PM
shun_kim's Avatar
Just had the same kind of problem. I had my alternator tested. I end up changing the battery and everything is back to normal.
cycdaniel
Dec 17, 2019 10:58 AM
cak165
1G TSX Problems & Fixes
Sep 16, 2015 08:17 PM
mv01
Sep 15, 2015 10:36 AM
IndycarFaster
Sep 11, 2015 02:52 PM
jordanboi
Sep 5, 2015 01:33 AM
