Sunroof Rattle
Sunroof Rattle
So I was driving with the radio off last night and I started hearing a rattle coming from my sunroof as I was driving. It almost sounded like little marbles kept hitting it. It got worse as I went over bumps. Has anyone here experienced this?
Open your sunroof and apply white lithium grease to the rubber seal around your glass panel (spray on rag and wipe the rubber) and also spray the rails the roof slides on. Do the same with your windows and window track.
My sunroof rattles like crazy. I bought that white Honda grease to put on it, but it didn't help. I had the dealer look at it, that didn't help. Guess it's just something you have to live with, even though it is SO annoying, and really embarrassing when you have passengers.
Originally Posted by jlukja
The dealer was of no help? Its still under warranty right?
I have an 07, and I also had sunroof rattles. I would get the creaking sound when the sunroof was closed, and the shade was in the open position. After awhile, a rattle developed when the sunroof was in the tilt position. In addition to that, I was getting a "popping" type sound when I would open the sunroof (tilt or to fully open position). I asked the dealership to take a look at it during my second service. The tech liberally lubed the sunroof tracks, seals, etc with white lithium grease. I haven't had a problem since! Try that stuff, it works great!
boost owns
I took advice from a thread on these forums and bought some stuff at Home Depot called "Jig-A-Loo Spray". It's in an orange can. It's awesome. Basically you spray a bunch of it on a paper towel and apply it all over the rubber seal around the physical sunroof glass itself (use both the vent and open positions to get as much as possible) and also spray it into the tracks and basically all over the whole sunroof mechanism.
Stopped my rattling problem lovely. You have to repeat this process every couple of months but to me it's worth it, and cheap.
Originally Posted by CGTSX07
i have some silicon spray that i can use, but does anyone know where I can get this white lithium grease?
Just noticed that my sunroof also started to rattle........just like what CGTSX said, sounds like a marble hitting something..........
donno if that's due to the colder weather now in PA, kinda annoying, need to try those methods mentioned above.
I have had the same problem since I have had my 06. Instead of just closing the moonroof and the shade as well, I just keep it open on tilt all the time, even in the dead of winter just so I don't need to listen to it.
it's a car-drive it
Originally Posted by xenonhid
Damn! I have a 2005 with less miles than you! You must have done some major driving!
it's a car-drive it
Originally Posted by nj2pa2nc
how long have you owned your tsx? I bought mine new, one year ago 11/17. It has 31,250 miles on it now. i drive from nc to nj/pa and back alot.
i have a rattle in my sunroof as well, i took a look and noticed this plastic bar was casusing it, when i open the sunroof thou if dosnt rattle, only when closed.
I had this problem in my 04. Seemed to occur in warmer months when it was more humid (but not wet). Sounded like ice cubes colliding with the walls of a plastic cooler filled with ice water. They lubed mine but it would eventually come back in like a month. Finally they applied some clear tape to the surface of the roof that the rubber perimeter of the sunroof touches and I've not had the problem since. The job is clean and you have to look for it to see it, and even then only when the glass is open.
Unfortunately I still get this problem with my side window seals and don't expect to be able to solve that one permanently.
mlody
12-04-2019 02:11 PM
jaynatlanta
5G TLX Problems & Fixes
09-15-2015 11:08 AM
