Sudden loss in low end power
Old Jun 13, 2005 | 12:29 PM
NJtsx's Avatar
Automobile Aficionado
Recently i have felt a definate loss in low end torque. I checked the few things i thought it could be, but nothing. I have the car for 2 years with 27,000 miles on it. So i can tell when it drives different. My injen is connected all properly, no need for an oil change. Maybe its just the recent 90 degrees heat? I am little worried about it. Any suggestions?
Old Jun 13, 2005 | 12:32 PM
CGTSX2004's Avatar
The combination of heat + humidity in the air might be partially attributable for the power loss, but if it's really significant, might not be the hole explanation. Are there any other symptoms (like increase of noise, etc.) that might indicate something else on top of the added heat?
Old Jun 13, 2005 | 12:41 PM
05_TSX_GP's Avatar
Top notch 6MT
Also, can you definitively recall the timing of this loss of low-end torque with the heat in your area?
How long have you had your Injen? First Summer with it on? When I had my '98 Prelude, I definitely felt the loss of torque in Summer time after I had put on the SRI.
Old Jun 13, 2005 | 01:04 PM
jiggaman's Avatar
I spend 2 much time here
have you had your AC cranked?
Old Jun 13, 2005 | 01:20 PM
JTso's Avatar
Bad tank of gas causing the ECU to retard timing?
Old Jun 13, 2005 | 03:09 PM
kurt_bradley's Avatar
You would definately get a CEL for that. It would throw it for misfires, not just retard the timing for bad fuel.
If a driver has an SRI, they need to consider a Hondata heatshield gasket. If the air is dense in addition to hot, power will suffer dramatically under heavy loads.
Old Jun 13, 2005 | 05:44 PM
leftride's Avatar
i want to ride my bicycle
i vote a/c
Old Jun 13, 2005 | 06:35 PM
Arcticcl9's Avatar
Can't wait to drive
check for cracks or holes in the exhaust or intake..that can cause drop in low end power.
Old Jun 13, 2005 | 08:05 PM
McGriddle's Avatar
Mmmm... tasty.
It's the heat + humidity! I've lost a bit of low-end torque lately, too. 90+ degress in Jersey will do that to ya.
Old Jun 13, 2005 | 08:36 PM
NJtsx's Avatar
yea a/c would be obvious answer but i never use it, even in 90 degree heat. Bad tank a gas maybe but i think i have refueled acouple times since i noticed.
i dont really recall when it started, before this recent heat wave i think.
i am thinking something with the intake. This is not the first summer with it though.
the loss is most significant around 2,000-3500 rpms
Old Jun 13, 2005 | 08:47 PM
daddydliv's Avatar
Faster, please.
Must be the heat. I've noticed the same thing and kinda figured the same reason. I never thought I'd find another reason to miss winter (the only other one being Christmas).
Feb 25, 2020 09:57 AM
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
Sep 17, 2015 10:16 AM
PortlandRL
Sep 14, 2015 12:01 PM
Desert Ridge
Sep 5, 2015 09:47 AM
