Strange Engine Sound
Old Feb 15, 2007 | 09:43 PM
TSX2006's Avatar
Recently I noticed that when I let go of the gas after revving to at least 3k rpm, there is a light 'grrr' sound coming from the front. So it goes like 'vrrrooomm' and then 'grrr'' once I let go of the gas. I don't notice this under 3k rpm. Its very noticeable when doing this while car is parked and in neutral. Any idea what it could be?
Old Feb 15, 2007 | 09:51 PM
dolparism's Avatar
my car has been doing it, too....between rpm range of 2.5k to 3k.....when i use bluetooth, the person who i am calling will hear metal sound....like u finish up a drink with straw....
but it is gone now..... i didn't do anything, but it is fixed.....
Old Feb 15, 2007 | 10:03 PM
dolparism's Avatar
by the way....i have 2006 mt
Old Feb 24, 2007 | 02:20 PM
junktionfet's Avatar
What does it sound like when you are stationary and the hood is open? Can you listen under the hood while someone revs the engine for you?
It could be a heat shield or perhaps some other loose part in the front of the car. Absolute worst case is a worn rod bearing (yikes).
Old Feb 24, 2007 | 02:21 PM
And does the noise go away when you have the clutch depressed? If so, it is chatter from the gearbox... the intensity of the chatter will dictate whether it is normal or not. A little chatter is fine.
Old Mar 2, 2007 | 07:41 PM
jiruhnungudah's Avatar
Exclamation weird sound..I
I have similar problem....except for me, itz continuous high tone sound. my car is only 3 days old... 07tsx auto. when i am drivin' in the city, it doesn't make any sound....but when i get on the freeway it starts to make a beeeeeeep sound that is very high pitchd. (i set cruise to 70mph and i was still able to hear it). goin' to dealer tomr to chk that out.....
Old Mar 2, 2007 | 08:31 PM
LoveMyTL-S's Avatar
I think you will find the high pitched whinning sound at high speeds is normal. I have it too. And I've seen a thread about as well. Seems to be normal with our transmission.
Old Mar 8, 2007 | 11:57 PM
matvey's Avatar
I have been hearing this noise on my car as well. I would hear this weird noise when I would let go off the gas at 3K RPMs or so.
Turned out to be my transmission had no oil it it!
My half shaft seal was leaking, and after I fixed that and filled it up with oil again, the noise went away.
uzzmaan
Aug 4, 2025 08:29 AM
Feb 25, 2020 09:57 AM
Dec 13, 2015 02:21 PM
Iain MacLeod
Sep 17, 2015 01:01 PM
Papa Roe
4G TL Problems & Fixes
Sep 1, 2015 09:41 PM
