Stinky TSX
So, do you like...stuff?
Stinky TSX
I saw a thread called "flatulance" a while ago, but couldnt find it. since the cold weather, my car STINKS like sulfur at least a few times per car ride -- it happens alot. even when i only rev to 3K, it still happens. i am going to have it checked onthe next service trip. is this happening to anyone else?
Not an Ashtray
Does it tend to happen only after you eat certain foods? ![Big Grin](https://acurazine.com/forums/images/smilies/biggrin.gif)
More seriously, I've read about this problem on Accord boards. Driver complain of the smell, but report that it goes away when the switch Gasoline brands.
More On
Re: Stinky TSX
Originally posted by RogerPodacter
I saw a thread called "flatulance" a while ago, but couldnt find it......
But I held my nose and found it:
![Bandito](https://acurazine.com/forums/images/smilies/bandito.gif)
http://www.acura-tsx.com/forums/show...&threadid=2934
Originally posted by hobbestec
I've noticed a little bit of sulfur like smell sometimes when I was using Exxon, so I switched to Mobil and I haven't smelled it since.
This is probably why your car smells:
http://www.clubtsx.com/bbs/showpost....7&postcount=58
Consider it a good thing...
![Boink](https://acurazine.com/forums/images/smilies/boink.gif)
More On
I get a weird smell from the ac when I first turn the car on... it goes away after a few min but I wish I knew ho wot stop it, my wifes 03 civic dose the same thing but its a lot worse. any suggestions? it dosent smell like a cat converter smell at all.
smelly car
actually, I am from Canada, and I first used Esso, and once I switched to Shell, there's no more smell. my friend told me that certain fuel has a high concentrate of Sulphur inside and when compressed with certain engines, it produces the smell. But now, it's A OK!
Originally posted by Kidd
if you use less than 91 octane in any of the new K series engines from honda... you will get that smell... its from the catalyistic converter.
![Confused](https://acurazine.com/forums/images/smilies/confused.gif)
I don't think that's where the smell comes from... octane level has nothing to do with it. It's depends on the temperature of the catalytic converter... I suspect that the catalytic converter just got up to proper temperature and was in the process of burning away the chemicals but you may have ended your journey while this process was just starting to take place.
I started the flatulant (or however you spell it) thread and am still playing games with it and my wife (who bitches constantly about it).
I tried the gas switch (from Shell to Mobil). It worked for about one tank full and then the stank returned. Then I switched to Amoco and so far so good, but I'm just into my second tank. I'm expecting the smell to return.
I talked to a co-worker who has a 2003 Accord EX. It also has the Lev2 converter. He has no problem with smell.
I just know when I go to the dealer to complain about it, they are going to give me grief (if they even have the part in stock).
I looked up the price on a couple of the sights that someone else here had posted for parts and the cheapest price for our catalyc converter was around $620 with a list price of $800 something. Pretty obscene if you ask me. Wonder if the Accord uses the same part and what they charge for that. I see this crap all the time. We have a fax machine at work that has the same toner cartridge as one of our Lexmark printers. The price for the one for our fax machine is $150. The price for the one for our Lexmark printer is $75. Guess which one I buy.
Somebody said he saw this topic on an Accord forum or two. It would be greatly appreciated if you could post those links? I'd love to see what they have to say.
Oh yeah, almost forgot. I do get relief for a day or two if I run it hard for a little bit. That is, took it up to 7000 rpm a few times, using sportshift on my AT. Which makes me wonder if it just clogs up easily.
mlody
12-04-2019 02:11 PM
GWEEDOspeedo
01-15-2016 10:39 PM
