Squeaking RSB and Popping Suspension
Master Graphic Artist
Two quick problems I've noticed after my suspension setup has been in place for a while.
1. My RSB sqweeks in the mornings when the suspension is a bit tighter. After I drive over a couple bumps it goes away pretty much until the next morning. I guess I'll apply teflon tape and grease to those polyu bushings again.
2. When I was testing out the suspension I was doing circles in a cul-de-sac. I wasn't driving hard enough to lose grip but after a couple times around I hear a loud pop on my rear end. Almost sounds as if something snapped or a rock broke from under my tires. I tried it again the next day and heard the same thing. Both times I checked thinking I might've snapped the endlinks, but everything down there seems intact.. I wonder what that is... I know my springs have settled a while ago, the noise actually sounds like it did when they were settling in.
Any input on that would be awesome.
Driver/Detailer
Sounds like my experience with a thicker RSB. I left my car sitting for a week while I was out of state. When I got back, every corner and bump I go though gives a nice POP/Clunk/Twang sound. My rear sway was replaced only a month before going out of state. I loosened and retightened the endlinks and bushing mounts but it did not help. Finally I gave in and pulled the bushings off to regrease. Previously I was using the white stuff and noticed that it had dried out. I cleaned it up and used high-temperature lithium grease (used for caliper pins and a much thicker consistency) instead and the noises went away after about 10 minutes of driving. It's been a month now and no more pop/clunk/twang from the rear sway bar.
Originally Posted by Dan Martin
Sounds like the swaybar bushings are worn out. Time to pick up some poly bushings from Energy Suspension and call it a day. ![Nod](https://acurazine.com/forums/images/smilies/nod.gif)
Oh yeah, do we have a deal going on for those bushing on the forum?
I'm running a Progress RSB, which I'm told comes with poly bushings (similar or identical to ES). I've been running it for over 10k miles and not 1 pop or squeek since it settled on day 1. Just letting you know there really is something to this Poly Bushing thing. It did also come with lithium grease which I applied and may be helping, but I've never even checked it since right after my first drive on it.
Someone stole "My Garage"
I have a Comptech bar w/ ES bushings and had a bit of a clunk around corners and on speed bumps that I didn't hit 100% straight. Also a loud creak when going over any bumps or other speedbumps.
I got udner the car, re-tightened the bushing bracket bolts to "pretty damn toight", and tightened the endlink nuts to "pretty toight", and everything has been fine ever since (about 10,000km ago)
The popping is still around.
I have a feeling it's coming from my rear coilovers. It only pops when I corner hard... sounds like when I first installed the coilovers and they started to set in.
I don't think it's from the RSB.
Anyone know how I can pinpoint / resolve this problem?
Driver/Detailer
Wrap some rubber tape around the top 3 coils of your coilover. You don't have to wrap it up completely, but at least have the rubber to stop the coils from hitting each other.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
adreano17
09-29-2015 08:48 AM
MrHeeltoe
09-28-2015 05:43 PM
