smoke or just cold outside?
Old Nov 27, 2009 | 03:56 AM
unoo's Avatar
so i was driving home from my girl friends house tonight and i was stopped at a red light with no one around.. so i floored it from the light all the way to redline and shifted to second and started to slow down when i got to 80km/h. i looked in my review mirror and saw a lot of white smoke.
now i warmed up my engine, it was at normal operating temp, under easy driving (slow acceleration/ cruising) there is no smoke, and my car says it is about 7 degrees outside so do you think it is just the hot exhaust meeting with the cold air outside or is it a problem in my engine?
thanks
Old Nov 27, 2009 | 11:02 AM
Itchytoe's Avatar
Modding newbie
Steam from the exhaust won't form a cloud of white smoke in your rear view mirror. You won't even notice the steam in your rear view unless you're sitting at a light looking for it.
Old Nov 27, 2009 | 12:16 PM
unoo's Avatar
this morning i drove it again was i think it only smokes when vtec is kicked in. could the smoke be caused by to much oil in the car?
Old Nov 27, 2009 | 12:52 PM
Itchytoe's Avatar
Modding newbie
Too much oil could certainly cause some of it to be burned off, especially in v-tec. Burning oil could cause such a cloud of smoke behind you. Did you overfill your oil? 5 quarts is ideal for the K24.
Old Nov 27, 2009 | 01:13 PM
unoo's Avatar
i didnt do my last oil change my dad did and he might of put a little to much in. i will check right now.
Old Nov 27, 2009 | 01:37 PM
unoo's Avatar
so i just checked and it looks fine. the oil is between the 2 dots on the dip stick but it is on the lower half if that matters at all.
Old Nov 27, 2009 | 03:49 PM
Itchytoe's Avatar
Modding newbie
Nah, your oil level is fine. Your engine may just burn oil in v-tec. Ever notice it get low just before a change?
Old Nov 27, 2009 | 04:29 PM
unoo's Avatar
nope the last change i did all if not like 99% of the oil came out.
Old Nov 27, 2009 | 05:19 PM
unoo's Avatar
so i drove it around some more. i turned the stereo off and listened to vtec at 6k RPM and when it kicks in it sounds like hot water boiling and sizzling in a way. and it sounds like it is coming from the passenger side any ideas? i have no idea what would make that sound
Jul 16, 2017 07:33 AM
rcs86
Aug 2, 2016 06:52 PM
jmaxima03
Sep 27, 2015 10:22 AM
prbori
Sep 27, 2015 01:37 AM
