RPM Surges
RPM Surges
I have a 2007 TSX. When I apply the brake at a higher speed the rpm's surge to about 3,000 or higher until I pop the gas pedal to bring it down. It started as a once in awhile event and now happens every time, seems to be downhill or on an even surface. I have 65K miles on the car and the dealer said to bring it in for a 60K service and they would adjust the idle. I'm thinking that isn't the problem. The car doesn't jerk or do anything except suck gas.
Check vacuum brake booster line and vacuum brake booster diaphragm for leaks. See following links or similar for procedure. Leaking vacuum will cause engine speed to increase.
http://www.ehow.com/how-does_4829365...-boosters.html
good luck
good luck
DerrickW
11-15-2015 05:52 PM
