Resurfaced Front Rotors @ 18k miles
So we all know I'm a bit of a spirited driver, but I am a great driver at the same time. I know how to properly brake and downshift, and I had to finally have my rotors assessed. I've been getting a little bit of vibration for the last 2 weeks, so I decided to have them checked out since I had the car in today to have the oil changed (with Mobil 1 of course) and the tires rotated & balanced. The pads are at about 8mm front and rear, but I had a 3mm variance in the front rotor surface. We resurfaced the front rotors to a true thickness and are hoping that this will last a little while. Otherwise, I'll be needing replacement.
I guess I'm now part of the warped rotors club.
I too am a pretty spirited driver and have been using proper braking technique. My car has 21k miles on it right now and while the rotors themselves probably aren't warped, I can tell that there is pad material that has adhered to the surface unevenly resulting in a little stutter when I hit the brakes hard. Annoying, but will get dealt with when I switch to my front pads to Hawk HPS pads.
Originally Posted by jmathew34
did you take it to the dealer to get it resurfaced? did you have to pay?
Originally Posted by poltergeist
Hope that's a misprint, because there's no way you could machine out 3mm of runout/parallelism variation from the front rotors and still be over min. thickness. .03mm maybe?
asahrts
Sep 4, 2015 05:55 PM
