Engine vibration- Up Date
Old Mar 16, 2005 | 08:54 PM
vitus's Avatar
Exclamation Engine vibration- Up Date
Hey Guys,
It has been a long time since my last post on this thread about my TSX.
I took my TSX to a Honda Dealer and the Service Manager confirmed my engine vibration is the same as the vibration on 2003-2004 Accord.
Due to the over loaded complaints received ,Honda came out with a Modification Kit for the Accord for this issue. By adding a balance weight at the front of the engine to off set the un-balance # 4 cyclinder due to the A/C compressor comes On/Off when auto climate control is selected.
He suggested me to make a series complaint to Honda and hopefully this will give them pressure to come up with a Mod Kit for the TSX.
Hey guys, if you have the same issue please work with me . Start writing complaint to Honda. Hopefully the more complaints they received this will force them to come up with a Mod Kit ASAP .
Acura Client Services
1919 Torrance Blvd.
Torrance, CA 90501-2746
Acura Customer Relations
Mailing Address:
Honda Canada Customer Relations
715 Milner Avenue
Toronto, ON
M1B 2K8
Number: 1-888-9-ACURA-9 (1-888-922-8729)
Hours: 8:00 am to 7:30 pm Monday to Friday (Eastern time)
Old Mar 16, 2005 | 09:51 PM
TinkyWinky's Avatar
TSX User
Interesting, I also noticed some vibrations in my TSX when I turned on the AC today.
There must be such a kit available in Japan or Europe already, no?
Old Mar 17, 2005 | 01:13 PM
vitus's Avatar
Tinky Winky,
If you notice a vibration now and it will get worse because once your engine all run in and everything start losing up , this will get worse.
Take it back to your Dealer and ask them to look at that. Dealer has to file report every month to Honda , any complaint that the Dealer is unable to fix , the engineering department has to come up with a solution.The more complaint they receive and this will force them to act faster to come up with a Mod kit.
This Mod kit is already put in the 2003-2004 Accord but Honda has to go thru all the engineering process and also has to submit to TSB to get approval.
uzzmaan
Jun 17, 2026 08:56 PM
vpasla1
Sep 17, 2016 07:24 PM
Sep 21, 2015 08:44 AM
Iain MacLeod
Sep 16, 2015 02:38 PM
