Removing the Hazard Light Button
Old Oct 17, 2007 | 03:14 PM
dennyslick's Avatar
6th Gear
I want to remove my head unit to get to a rattle that's been driving me nuts, and there is a screw I need to remove that sits behind the hazard light button. From the service manual and doing a search in this forum, it looks like you are supposed to just pull these out, but I am having the toughest time doing this.
Is there a special technique that I am not aware of? I can barely grab hold of the button, let alone get enough leverage to pull it out. Is there a tool I could use? Any tips?
Old Oct 17, 2007 | 05:33 PM
clee109's Avatar
I Quit
I'm not sure how it comes out, but if it's like you say and just prying them out a panel popper should do the job. Or you can try one of those very small flat head screw drivers that you get to tighten eye glasses
Old Oct 17, 2007 | 07:44 PM
poltergeist's Avatar
At least for '04-'05....
The hazard switch comes out as part of the black rectangular panel that's between the two air vents. The switch itself (triangle) is screwed to the back of this panel.
mada51589
Jan 9, 2025 04:40 PM
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
PortlandRL
Sep 14, 2015 12:01 PM
