Rear Rattle
Old Aug 9, 2003 | 11:02 AM
brerpie's Avatar
CeD
Rear Rattle
Hey all,
Does anyone else have a constant rattle coming from the rear of the car? I can't decipher exactly where it is coming from... however, it seems as if it might be from the rear headliner or somewhere in the rear seats.
Anyone have this? Mine is very loud, annoying and constant.
Any quik fixes?
Old Aug 9, 2003 | 11:37 AM
lshenretty's Avatar
Don't have mine yet, but is it possible the rear seat latch is not fastened?
Old Aug 10, 2003 | 08:15 PM
brerpie's Avatar
CeD
Anybody?
Old Aug 10, 2003 | 08:17 PM
fdl's Avatar
fdl
Can you describe your noise a little more? I hear a ticking sound when i go over bumbps. It seems to be coming from the rear headliner..maybe. I havent paid too much attention to it because I have so many other rattles that I am more concerned about.
Old Aug 11, 2003 | 01:30 PM
dxk9136's Avatar
Rear side air bag cover rattle
Make sure your rear air bag cover is on tight. I was getting the same rattling noise from right rear when I turned on the radio. Checked the right rear air bag and noticed it wasn't on tight like the left one. Hope this helps out.
Old Aug 11, 2003 | 06:33 PM
brerpie's Avatar
CeD
Airbag cover is tight. I just checked and everything seems to be fitted correctly. I don't know where it's coming from. I guess i'm the only one having this rattle.
Old Aug 11, 2003 | 07:08 PM
nuke's Avatar
Nuke
maybe check the tools over the spare tire and the space around the spare tire..also do you have anything at all in the back seat or on the floor..if I throw my case in the back, the zipper sometimes rattles on it.
Old Aug 19, 2003 | 06:49 PM
LeMasseHammer's Avatar
Re: Rear Rattle
Hey all,
Any quik fixes?
One of my noises was from the rear headliner brushing against the roof of the car. The transition is not high quality, which you'd never know unless you check it out carefully. You can test/reproduce the noise easily, just by tapping against the edge of the headliner where it meets the top of the rear window. The dealer fixed it fast after I made the diagnosis.
Old Aug 19, 2003 | 08:53 PM
Stash's Avatar
take a ride in the back seat and then in the trunk and see what you hear
Old Jul 29, 2005 | 11:08 AM
RX8's Avatar
RX8
Headliner brushing against roof- how did they fix it?
Hey Hammer-
How did the dealer fix this problem of the headliner rubbing against the roof? I have it, too. I am thinking a very sharp utility knife will fix the problem. It's obvious & really annoying, but I don't feel like taking the car into the dealer with all of 225 miles on it.
There are other rattles, too, that I need to find and isolate first.
Jeff
Old Jul 30, 2005 | 01:04 PM
RX8's Avatar
RX8
hah. Fixed it myself. I pulled the headliner down a little in back (it's not attached near the rear window) and stuffed some foam between the headliner and the roof. That added enough clearance that the headliner foam isn't rubbing against the glass any more. Quiet!
I also think I nailed a glovebox rattle, and thanks to another thread, a rattle in the map light/navi mic unit. *crosses fingers*
marcelft
Jul 10, 2018 06:17 PM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
jaynatlanta
5G TLX Problems & Fixes
Sep 15, 2015 11:08 AM
3GTLOwns
Sep 9, 2015 09:51 PM
