Problem with jacking up?
Old Jul 7, 2006 | 10:51 PM
joerockt's Avatar
Just dial 1911
Exclamation Problem with jacking up?
Since the wife is out of town for a few days, I figured now would be a good time to see what's involved with installing the CT heatsheild gasket. So, I go to lift the car as I've done so many times in the past, and this is happening:
How in the hell am I able to jack up the entire side of the car from just the front??? I've never seen this happen before. Whats worse (or better) is that I tried the other side and got the same result. I dont know if I'm just losing my mind or if this is normal. Can anyone confirm this? Im just hoping I'm not having a problem with the rear Tein's.
Side note, I just got back from a 500 mile round trip to Vegas.
Old Jul 7, 2006 | 11:01 PM
PWPTSX's Avatar
hey i notice the same thing when jacking up my car in the front, the jack actually lift up the whole side of the car! i was like what????? weirdd...................
Old Jul 7, 2006 | 11:17 PM
CGTSX2004's Avatar
Do you have both rear jackstands in place?
Old Jul 7, 2006 | 11:26 PM
joerockt's Avatar
Just dial 1911
No, just on that one side. I did it for now because it just didnt seem normal to have all that weight on the jack point in the front...
Old Jul 8, 2006 | 07:46 AM
taz98spin's Avatar
That has never happened for me before.. strange...
Old Jul 8, 2006 | 11:03 AM
pizzaman555's Avatar
Did you recently lower the car if you did maybe that could be the cause. After I lowered my car I am now able to jack up the whole side of the car with one jack.
Old Jul 8, 2006 | 12:47 PM
aaronng's Avatar
Driver/Detailer
I have another question. My jack can jack up the front at the center to put jackstands for the front jackpoints. But it is impossible to do for the rear because the jack doesn't go high enough. Any suggestions? Other than a car lift of course.
Old Jul 8, 2006 | 01:35 PM
joerockt's Avatar
Just dial 1911
It was lowered about a year a few months ago. I know for a fact that I've lifted it since then because I always take off the passenger side wheel to do an oil change so I can get to the filter. I would have noticed this then...
To me, it looks like the rear isnt dropping as far as it should. Its almost like the coilover is still under load
Old Jul 8, 2006 | 04:47 PM
I wouldnt worry to much if the car drives fine.
Old Jul 8, 2006 | 05:05 PM
hondatypes's Avatar
isnt this normal?(rsb) my car isnt drop nor any suspension mods!!
Old Jul 8, 2006 | 05:31 PM
JTso's Avatar
Get a low profile high-lift jack.
Old Jul 8, 2006 | 05:36 PM
joerockt's Avatar
Just dial 1911
No input from you for the actual topic?
Old Jul 8, 2006 | 05:58 PM
JTso's Avatar
Haha... what you experienced is normal, especially if you have a larger RSB. All my modified cars are like that.
Old Jul 8, 2006 | 06:35 PM
joerockt's Avatar
Just dial 1911
Ok, well I feel better know I have no idea why I never noticed this before...
Old Jul 8, 2006 | 06:40 PM
JTso's Avatar
If you have shorter aftermarket shocks, it doesn't take much lifting from the front to raise the rear.
Old Jul 8, 2006 | 09:56 PM
kboosman00's Avatar
no0bIe
I live in Vegas, sure wished you would have told me. I would of been glad to meet you.
Old Jul 8, 2006 | 10:37 PM
joerockt's Avatar
Just dial 1911
I went to see Pearl Jam with a friend, drove up Thursday, came back Friday. Next time I'm out there, I'll hit you up
Old Jul 9, 2006 | 08:48 AM
curls's Avatar
Someone stole "My Garage"
Lift front - place front jackstands
Lift rear - place rear jackstands.
I like this method in the absence of a low-pro, high-lift jack. It works just fine.
Old Jul 9, 2006 | 09:58 AM
aaronng's Avatar
Driver/Detailer
We have tried using a racing jack as well, but we couldn't get the rear up high enough to place the jack stands in.... The front was fine and dandy, but not the rear.. Time to buy a new jack.
Old Jul 9, 2006 | 10:32 AM
mercman's Avatar
It’s normal.
If you want to lift the front only then jack one side and place a jack stand, move the jack to the other side and start jacking. The opposite rear wheel will return safely to the ground. Install the second jack stand chock the rear wheels and have fun.
jeff
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
SUPRMN84
Oct 7, 2015 09:46 PM
navtool.com
Sep 25, 2015 05:15 PM
