Over filled oil a bit
Old May 11, 2005 | 08:05 PM
Honda2.4's Avatar
The oil is slightly above the top whole. Is this bad and should I drain some out?
Old May 11, 2005 | 08:11 PM
JTso's Avatar
If it's just a little bit, I wouldn't worry about it.
Old May 11, 2005 | 08:12 PM
Dan Martin's Avatar
Photography Nerd
Wait a second, do you mean over the top of the fill line on the dipstick or do you mean it's coming out the hole you poured the oil in?
Old May 11, 2005 | 08:18 PM
JTso's Avatar
It would be scary if that's the case.
Old May 11, 2005 | 08:20 PM
Honda2.4's Avatar
No just over the top whole on the dipstick. If this is the whole 0 * , the star is where it's at.
Old May 11, 2005 | 08:32 PM
Dan Martin's Avatar
Photography Nerd
Ok, just had to make sure. Ya, you'll be fine.
Old May 11, 2005 | 10:00 PM
xizor's Avatar
Bye TSX, hello domestic?
you could just leave the oil cap off and start the engine, the oil will come out no problem (SRT4 joke)
Old May 12, 2005 | 08:16 AM
Viking's Avatar
Quattro in.....
Old May 12, 2005 | 08:53 AM
sauceman's Avatar
Moderator Alumnus
OMG we need to bring this thread back to life for the n00bs.
Old May 12, 2005 | 10:02 AM
Arcticcl9's Avatar
Can't wait to drive
I would drain a bit of oil (or drain completely and refill to proper level) as soon as possible
The least it could do is lost of a little fuel economy and performance.
The worst it could do, if you drive for a long time and hard is oil foaming, or break an oil gasket!
Old May 12, 2005 | 10:34 AM
vwong's Avatar
n00b
It's not a problem. I overfilled my motor every time I go to auto-x or track day. The level of overfill is usually about 1/8" to 3/16" above the top mark. The only ill effect of overfilled motor is a bit of hp loss.
Old May 12, 2005 | 03:45 PM
Honda2.4's Avatar
Thanks. What I ended up doing is changing filters. I took off the Purelator Pure One and replaced it with a K&N (simply bc it's easier to get them off). It then took the oil level to exactly the top hole. vwong is correct though after researching it abit. Put it this way, if it were a problem, Honda would have a ton of issues with their cars because most quick lube places either under fill or over fill cars.
Old Jul 26, 2005 | 12:54 PM
dontcare4urshyt's Avatar
im not sure about the TSX motors. but i have a Seadoo RXP and I filled it to the line nothing above. then ran the ski. when the engine was hot the oil level was significantly higher then the top mark. needless to say i damaged te motor and it was not warranteed. Id stick something down the filler and pump out a little oil to be safe.
Old Jul 26, 2005 | 01:10 PM
JTso's Avatar
It doesn't hurt anything if it's only a little higher. Guess what happens when the engine is running? Oil circulates the entire engine from the oil pickup, oil pump, oil filter, then to the various bearings in the head and in the block. The oil level will never be at the top mark during running. That's the same reason you need to let the engine sit for awhile before checking oil, to allow oil drain back to the pan.
mada51589
Jan 9, 2025 04:40 PM
foxriderar77
Nov 19, 2020 10:17 AM
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
01CLOwner
Oct 9, 2015 01:07 PM
Frathora
Sep 28, 2015 11:29 PM
