odor because of humidity
Old Nov 1, 2005 | 03:38 PM
blahsome's Avatar
My TSX's AC system, because of the humidity in the city I live, begins to develop some serious odor that resembles, say, horse manure.
I have heard that professional service can get rid of this problem (by flusing the entire AC system?), at least temporarily. I have also heard it's not cheap.
Has anybody used the service before? Can the dealer do it?
Thanks.
Old Nov 1, 2005 | 04:35 PM
joerockt's Avatar
Just dial 1911
Thanks.
Naaa, dont bother with that. Just turn on your AC full crank with the vent OPEN. Grab a can of Lysol and start spraying into the air intake just below the driver side wiper.
That should do the trick. May need to do it every few weeks.
Old Nov 1, 2005 | 05:10 PM
jlukja's Avatar
Old Nov 2, 2005 | 10:57 AM
blahsome's Avatar
Thanks a lot. Which Lysol product will I be using then? A spray or the all purpose cleaner?
Spray Air Sanitizer
Disinfectant Sprays
Toilet Bowl Cleaners
Bathroom Cleaners
All Purpose Cleaners
Old Nov 2, 2005 | 11:10 AM
TSX6one9's Avatar
Spray Air Sanitizer
Old Nov 2, 2005 | 11:50 AM
jlukja's Avatar
It needs to be a spray. Aerosol is better. It needs to kill bacteria and mold.
Old Nov 2, 2005 | 12:23 PM
joerockt's Avatar
Just dial 1911
I would just use the straight up disinfectant. I dont know if the Spray Air Sanitizer kills mold, which is probably what your up aganst.
Old Nov 2, 2005 | 07:29 PM
Dr.Evil's Avatar
Arm the " Laser "
MILDEW. I had this same problem just a few weeks back. I didnt use the A/C over the summer and when i used it for the first time since the cabin reeked like a " spoiled meat " like when u leave a steak to defrost and forget abt it.. that dried up blood smell Yeck. Others describe it as a wet sock
Turn the A/C on hi on fresh air setting. Spray Lysol over the vents near the windshield. Have it run for a couple of minutes. I also changed the vent settings in between sprays to cover all the possible locations the $#%%@ spore can hide
Did it several times over a couple days and it didnt come back since.
Old Nov 2, 2005 | 07:57 PM
r33p04s's Avatar
i have the same problem...mostly right after a rain when the humidity is fairly high...i'm gonna try your lysol solution hopefully it works becuase the smell i get is a soggy smell...like the carpet or something got wet n is just sitting there
Old Nov 2, 2005 | 08:10 PM
joerockt's Avatar
Just dial 1911
Uhhh, why??
Old Nov 2, 2005 | 08:34 PM
eviljai's Avatar
y dont u guys buy an air freshner?? just my .02
go on ebay, air spencer makes some good air freshner = )
may be that will help a lil
Old Nov 2, 2005 | 09:02 PM
joerockt's Avatar
Just dial 1911
That wont help shit. You need to kill the mold and mildew inside the system thats causing the smell.
Old Nov 3, 2005 | 12:08 PM
Dr.Evil's Avatar
Arm the " Laser "
Uhhh, why??
The summer wasn't that hot here in Seattle.... had to enjoy the sun while it lasted... the Seattle Rain Festival is back in town
>>> Yep!... all you get is Lemon-Scented Mold and Mildew
Old Nov 3, 2005 | 12:30 PM
gsclifton's Avatar
ABP TSX
I have used this on three cars before but not the TSX. It worked perfectly.
"Don't mask odors with fragrances -- treat them. Klima-Cleaner is an effective means for removing odors from the air conditioning unit by eliminating odor-causing bacteria, fungi and other germs. Works by effectively cleaning the evaporator -- the source of the problem. Simply insert included spray hose into the center air vents in your vehicle's interior and spray. Allow to work for 30 minutes. Creates a healthy and fresh smelling environment that lasts for months. 250 ml aerosol"
Product Link
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
max4swag
Sep 14, 2015 07:55 AM
fuckleberry
Feb 16, 2006 08:17 PM
gavriil
Oct 26, 2003 07:36 PM
