Non Functioning Navi
Old Jun 28, 2011 | 12:12 PM
thunder04's Avatar
Sweet!
For a couple of weeks, my nav unit was acting strange. After the initial splash screen, the display would stay black from anywhere between 30 seconds and 15 minutes before it'd show the disclaimer that you have to hit "OK" for (yeah, I know there are mods around that lol).
Also, every once and a while the GPS would lose track of my location and never correct itself. I have an hour and a half commute one way, uncovered, so it has plenty of time to fix itself!
I'd go into the "secret" menu (by holding Map + Menu + Cancel) and run all of the various tests. They'd all pass.
However, on my way home last night this happened early into my drive home. This time, one test failed. GPS under the Navi ECU test failed with "NG". Switching to the GPS info page showed that it'd see a handful of satellites, then they'd suddenly disappear. This happened over and over. It never "locked" to any satellite, they all remained as "searching".
If I reboot the nav unit, it displays the splash screen, then the display goes black, and that's it. It still responds to the "Map + Menu + Cancel" menu and the same item under the same test fails.
The GPS antenna connection seems to pass, so I'm not sure what's up.
My guess is something needs to be repaired, but which component? Is the drive in the trunk just a drive or is it also the nav computer?
Old Jun 28, 2011 | 12:19 PM
try swapping disc with some one.
that will narrow it down to the drive.
Old Jun 28, 2011 | 12:25 PM
thunder04's Avatar
Sweet!
There isn't anyone I know with a 1G TSX /w navi near by.
I could try swapping the CD (I have the original maps CD), but I've been running the '06 maps since, well, 2006...so the problem being a software problem doesn't make sense...unless the CD got damaged somehow.
If the drive was having trouble reading the CD, wouldn't it display a read error (or something similar)?
Old Jun 28, 2011 | 12:28 PM
I dont know too much about how the nav system works, but it seems like you cant get a signal.
Hope you get it narrowed down.
Old Jun 28, 2011 | 12:33 PM
thunder04's Avatar
Sweet!
Me too.
Old Jun 28, 2011 | 07:34 PM
Miamicarfan's Avatar
Did you recently tint your car windows?
Old Jun 29, 2011 | 09:48 AM
thunder04's Avatar
Sweet!
No, they've been tinted since '06.
Old Jun 29, 2011 | 09:50 AM
thunder04's Avatar
Sweet!
I tried to demonstrate the problem in this video:
http://www.youtube.com/watch?v=UfFfLptuscE
Old Jun 29, 2011 | 03:04 PM
PaHonda's Avatar
I would call alpine and ask them what you need to send them for repair, or if there there may be some other fault.
This thread gives the 800 number.
https://acurazine.com/forums/1g-tsx-2004-2008-124/04-navigation-unit-676207/
Old Jul 3, 2011 | 04:41 PM
thunder04's Avatar
Sweet!
It's been working the past few days...once it starts acting up again I'll definitely give them a call.
~ Anthony
4drviper
Apr 23, 2025 07:13 PM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
soupi
14
Nov 15, 2015 11:15 AM
lanechanger
Oct 13, 2015 10:56 AM
Cgannotti
Sep 25, 2015 05:04 PM
