Noise with the brakes
I have an 06 tsx running around 33,000miles. I recently replaced my rear break pads 3 weeks ago and I am still hearing a consistent good amount of noise whenever I press on the brakes and often times when I'm not pressing the brakes. It sounds like metal grinding or the noise that brakes makes when the break pads are gone. The brake pads front is at 4mm and rear is at 5mm. I was just wondering if any of you know if this is normal or what the possible problem could be. Thanks
04 abp tsx
i have an 04 and i got my front brakes done at tire kingdom( this was b4 i knew thats the worst place to bring ur car in the world.) but newaz i had them replaced there but there was still that same grinding that u are experiencing. took it to acura and said that alot of aftermarket pads dont work b/c of the TSXs brake assembly. they told me its a "floating brake assembly" or something like tht so i had them resurface the rotors and replace the pads.... again.... and problem was solved. but if acura replaced them then i dnt really know what to tell you besides bring it back and tell them to fix it.
You don't state what replacement pads you used, but it could be that you didn't set the new pads in properly. Or maybe you didn't install the new pads properly. I'm interested to hear from others on this; there's not too much that can go wrong here.
04 abp tsx
id what brand pads tire kingdom used. i could very well be that they just suck but i checked it out after they wer done and everything seemed to be in right. i replaced my back pads myself. used ceramic pads i got from autozone. cant remember what brand but they worked perfectly. but the acura service guy said ther are some aftermarket pads wont work right.
I had the grinding noise until I replaced by rear brake pads this weekend (easy to do, thanks to whomever suggested to use a cube-like tool to retract the pistons). I can't remember the brand of the pads, but it seems to be working well, it was on sale at Advanced Auto. I plan on replacing the front pads this weekend and probably use the same brand of pads.
I have a '05 TSX AT with about 66k miles and I have been having a similiar grinding noise, almost like a metallic bubbling/gurgling noise when braking (I'm horrible at describing noises apparently). Anyways, back at about 36k miles my friend, who races BMWs outside of work, helped me replace the front and rear pads and rotors after having the dreaded warped rotor problem. We used solid Brembo rotors and Hawk HPS pads. That fixed the vibration problem and I thought all was well. A couple months go by and I notice a little bit of noise when braking as well as a squeaking noise when making left hand turns so I took it to the dealer. There was a small rock in between the rotors and pads and when that was removed the squeaking noise stopped, but the grinding/gurgling sound remained. The dealer said the same thing about the aftermarket pads possibly being the cause. The reason I'm posting now is that the noise has gotten louder and more frequent lately.
Has anyone else heard the explanation that janob and I got? Does anyone have any suggestions on anything else I should be looking at?
My friend and I just flushed out the brake fluid, but that didn't help. He checked the pads and rotors and said everything looked OK. I also bought some new tires from Mr. Tires and they have about 7k miles on them now. I just had them rotated (and possibly balanced) at Mr. Tire for free as part of the deal you get when you buy from them, but the noise still is still there. I can't remember when the noise started getting worse but it was probably close to when I got the new tires, and was wondering if that could possibly have something to do with it.
Any suggestions would be much appreciated.
Thanks!
Thanks!
Thanks!
Thanks!
resident asshole
I replaced my rotors and pads and now my car now makes an annoying scraping/squeal when brakes are not applied and I kinda would rather have the brake vibration than this annoying noise.
Experience with brakes and rotors
Just a little suggestion if you haven't already tried.
And remember
"If your wife or girlfriend don't find you handsome, at least they will find you handy"
-Red Green-
- For the squealing brake pads. Did you remember to put braking grease on the areas between the pads and the master cylinders? For example the shims, usually those little metal plates, which are sadly necessary, can be the source of the resonation. It could possibly help with the gurgling/scraping noise.
- Also, the materials that are used for the brakes can affect the type of scraping noise you get too. Harder brake composite materials can be the case.
- The vibration that you get when you brake could be the results of to many dead stops and then resting on brakes. Once they get heated and you stay on the brake at stop the rest of the rotor cools quicker and then warps it.
And remember
-Red Green-
GWEEDOspeedo
01-15-2016 10:39 PM
joflewbyu2
10-08-2015 11:16 AM
4drviper
09-23-2015 09:00 PM
