changing rotor/pads cause steerwheel vibration?
Old Aug 23, 2009 | 02:15 AM
maclion's Avatar
I just changed pads and rotors for 05 TSX by myself. Now I can feel a little bit of vibration at 80 mph (sometimes at 62mph). this vibration is not very noticeable, but still there. Wheel balance has been done 2 months ago.
Do u guys think changing rotor could cause such problem, e.g., rust (between rotor and hub) not lubricated, lug nuts not torqued correctly et al. Or I should re-balance wheel?
Old Aug 23, 2009 | 06:51 AM
EvolveTSX's Avatar
me thinks the 2 bolts that hold the rotor are not tight enough or you could be right about the rust between the rotor and hub. I'm assuming you torqued the lugs to 80? Hope you find out your problem!
Old Aug 23, 2009 | 01:12 PM
maclion's Avatar
I thought the 2 bolts holding rotor are useless. I will tight them by impact dirver. \
Thanks.
Old Sep 10, 2009 | 06:34 PM
EvolveTSX's Avatar
did the screw tightening fix the vibration?
Old Oct 6, 2009 | 07:20 PM
canoepus008's Avatar
If that didn't fix it...
It might be, dare I say, user error...
Dead stops and then staying on the brake can cause the rotor to warp. Easing up on the brake and rolling the stop should help.
"If they(wife or girlfriend) don't find you handsome, at least they will find you handy"
-Red Green-
Old Oct 7, 2009 | 04:48 PM
Tsx6363's Avatar
-Red Green-
i think theres a thread on here that argues the opposite... that braking hard and biting the pads causes less heating/wear.
Aleax
Sep 11, 2015 11:31 AM
kuzdu
Sep 10, 2015 08:42 PM
mav888
1G RDX (2007-2012)
Sep 8, 2015 11:49 AM
thisisnotdave
4G TL Problems & Fixes
Sep 8, 2015 10:02 AM
nishant11
Sep 2, 2015 10:34 AM
