new problem...or not?..help
Old Jun 25, 2008 | 10:39 AM
yaze21's Avatar
D.L.T
Ok guys this might not make any sense but ill try to explain as much as I can..because I guess you have to be in the car to really notice. Well my problem is not long ago I started to notice that my car sounds like I have an intake or something...which I don't...everytime I hit 55mph or above my car has that sound I thought it was the exhoust but I took it to the machanic n they said is fine can't find anything...I do a lot of highway driving I have an 04 with 70k so when I drive I hear it towards the back seats...is just real hard to tell here...sounds like a g37 but not quite like it...so do you guys have any idea what could it be? Plz help is gettin to me so bad
Old Jun 25, 2008 | 10:50 AM
moda_way's Avatar
Assuming you don't have any mods, it could be an exhaust leak on top of the pipe, so difficult to see. There is really only 2 major joints in the stock exhaust, one being in the rear.
Old Jun 25, 2008 | 10:55 AM
yaze21's Avatar
D.L.T
So how would I fix that?..and the leak would be the cause of the loud noise?...and u right..mine is stock everything...but would that effect anything?..or would it go away by its self?
Old Jun 25, 2008 | 11:54 AM
MMsTSX's Avatar
JDM Addict
ah....
how would a hole just go away by itself?
it wouldn't.
it would be hard to see because it would be on the top of the pipe.
meaning you would have to drop the exhaust and inspect it to see it.
yes, exhaust leaks cause loud exhaust noises.
stock or not would effect nothing.
just where the noise would possibly coming from.
if it's really bothering you, have your exhaust fully inspected.
meaning all the way around all the pipes.
have it smoke tested.
Old Jun 25, 2008 | 12:20 PM
yaze21's Avatar
D.L.T
Thanks guys...this is y this place is the best..u guys def help the ppl like me that don't kno nothing I just like to drive my car fast lol
Old Jun 25, 2008 | 12:23 PM
moda_way's Avatar
Well, don't take my suggestions as the answer. I mean, I personally would think you would hear the noise all the time if it were a true leak, I'm just voicing ideas at the moment.
Old Jun 25, 2008 | 12:36 PM
yaze21's Avatar
D.L.T
well i do hear it all the time now..but it wasnt really like that before thats why i have a concern. is always when i go more then 55mph ...so i mean should i still get it checked? for any leaks?
Old Jun 25, 2008 | 01:59 PM
moda_way's Avatar
I gotta say hearing it constantly makes me think so. If you do a hard pull up to 55, do you hear it? My question centers around creating pressure in the exhaust system and you say it is coming from the rear. There isn't much back there to make noise. There is the fuel pump in the tank, 2 wheel bearings, shocks, brakes, and exhaust. So eliminate the obvious ones that wouldn't make that kind of noise.
Old Jun 25, 2008 | 03:19 PM
LukeaTron's Avatar
Could possibly be a rear wheel bearing. Does the sound change with engine load or is purely speed dependent? Small exhaust holes are notorious for only making noise under specific conditions.
Old Jun 25, 2008 | 08:59 PM
yaze21's Avatar
D.L.T
Yeaaaa I was told today it was my rear wheel bearing....do u guys kno how much would it cost me?...n where I can get them besides the dealer
Old Jun 26, 2008 | 05:42 AM
moda_way's Avatar
You can check online parts stores. There is probably a cross-use with the Accord too, so buying the exact same part from Honda is usually cheaper.
EDIT:
42200-SEA-951
It is a bearing unit and what looks to be a rubber o-ring. ~$140 through an online Honda parts store. This is a direct match to the Accord.
Old Jun 26, 2008 | 10:52 AM
LukeaTron's Avatar
The old bearing will need pressed out and the new one pressed in too. Unless you have a large bearing press, you'll have to take the hub somewhere to have it done. It's enough of a hassle I'd just let a shop do it and I'm a very DIY person.
Old Jun 26, 2008 | 11:44 AM
yaze21's Avatar
D.L.T
thanks guys....42200-SEA-951 is that the part number?...and the honda will fit exacly to the acura?/.
Old Dec 5, 2009 | 06:37 PM
fury's Avatar
Bumping this thread.
I was at a Honda dealership today and they told me the 42200-SEA-951 is actually an Acura part number and they couldn't get it whereas 42200-SDA-A51 is for the 03-07 Accord. Anyone know if the latter will fit an 04-08 TSX also?
Old Dec 11, 2009 | 07:02 AM
yatesca's Avatar
6th Gear
I don't know if they are the same part number or not, but you can get the right one ordered from www.acuraoemparts.com.
I had to do this fix about 3 months ago. Only took about an hour.
mallo
Aug 29, 2013 01:40 AM
kmldiva
Jul 8, 2011 03:01 PM
tylerc56
Oct 23, 2006 02:52 PM
Larry6
Aug 12, 2005 10:03 AM
carswell
May 29, 2002 01:32 PM
