New car with a couple for Problems
Old Aug 11, 2011 | 03:32 AM
pimpshit's Avatar
6th Gear
I just bought a 05 tsx with 122,000 miles. Its got a couple of things wrong and wanted to get some advice/opinions on the matter. First of all i have done the plugs, Injector cleaning, TB cleaning, Air filter and checked the motor mounts for leaks. Now the problems It seems to have a rough idle and the rpms sometimes jump around. The second is the tranny seems to take a while to drop back into 1st after stopping, or if i slow down like im going to stop but then go agian it does down shift to first.
Any advise is good adivse
Joe
Old Aug 11, 2011 | 11:20 PM
main70072's Avatar
I would do a drain and fill on the tranny if that hasn't been done yet. Also, a bad PCV valve can cause poor idle.
Old Aug 13, 2011 | 02:04 AM
pimpshit's Avatar
6th Gear
Thanks for the advise. But it didnt work. Sorry I got a new PCV valve and did the tranny fill and drain 2 times and still nothing has changed. Any other things you might thing of?
Old Aug 13, 2011 | 10:01 AM
Boulder TSX's Avatar
Fuel filter? (That did the trick on my last car with a rough idle -- after I had tried everything else.)
No idea on the transmission. (I have a 6MT...and have never had an automatic.)
Old Aug 13, 2011 | 11:07 AM
Simba91102's Avatar
Old Guy
Joe
I have an 05 with 150K miles on it, so I feel I can speak from experience. That said, I'm a little confused about the injector cleaning (what is it and how do you do it) and the same thing with the throttle body cleaning. Neither of these things are manufacturer recommended service items, so I'm curious how and why I guess. It also makes me wonder if you might have done something in the "cleaning" process that effected the idle quality.
The transmission shifting methodology is not like many AT's, and if you're not familiar with it's shifting characteristics (especially downshifting), it may actually be working just fine, it's just that you don't know it. For those of us that are very familiar with it, it's tough to say judging by your description (for me anyway).
Old Aug 13, 2011 | 11:37 PM
main70072's Avatar
Just to clear things up for most of us, were these problems occuring prior to those maintainance processes? Like Boulder TSX mentioned, fuel filter may be the problem. Also, check vacuum hoses and intake hose for leaks/cracks.
As for the transmission, Simba91102 may be right about you not used to how these transmissions behave. I've noticed on mines that when in sport shift mode and slowing to a stop, the transmission don't shift to 1 until the car has almost stop moving. So did you fill the tranny with Honda fluid?
Old Aug 14, 2011 | 09:22 PM
pimpshit's Avatar
6th Gear
Throttle body and intake/injector cleaning is something that lots of people do. You should pull your intake tube off and look at the TB its dirty... No where in your owners manuel does it tell you to wash your car but im sure you do that. And i have owned about 15 differnet cars and have driven over 100 different ones too (used to work at a dealership) and i can tell you the shifting habits of this car is not normal. the fluid i used was bought from the acura dealership and i think it was the zr-1 stuff.
Old Aug 15, 2011 | 07:39 PM
Simba91102's Avatar
Old Guy
OK, thanks for the cleaning advice on the fuel system. I have had the tube off a few times when I remove the short ram intake for the state inspection. It looks clean enough to me, and I tend to practice the "if it ain't broke, don't fix it" philosophy. So....... I guess I'd be inclined to leave well enough alone since the car still runs like new.
As far as the transmission is concerned, I guess you more or less answered your own question. If you're convinced there's something wrong, it's unlikely you'll discover what that is here. I's say a trip to an Acua dealer is your best bet.
Old Aug 16, 2011 | 10:54 AM
pimpshit's Avatar
6th Gear
NOOOOOOOOOOOOO, My as well by a new car now. LOL Yeah thats what i was thinking but just wondered if anyone else has the same problem. Thanks for the help
Joe
Old Aug 16, 2011 | 06:18 PM
main70072's Avatar
^ Or you could take it to a reputable transmission shop like AAMCO that will check it out for you free of charge. Sorry about your misfortune!
Old Aug 18, 2011 | 12:00 PM
pimpshit's Avatar
6th Gear
Good idea. I think im going to try that.
Zonian22
Nov 14, 2015 01:20 PM
jordanboi
Sep 5, 2015 01:33 AM
NSolace
Sep 3, 2015 08:02 PM
Zonian22
Sep 2, 2015 08:19 AM
darknite123
Integra
Aug 30, 2015 03:00 PM
