Lowering and Headlight Aiming
Old Sep 21, 2005 | 11:38 PM
TSX 3Pedal's Avatar
Use all 3 Pedals at once
...any correltation?
For those of you who have lowered your cars, have you noticed that your visibility has decreased?
If so, have you reaimed your headlights?
Old Sep 22, 2005 | 11:35 AM
xizor's Avatar
Bye TSX, hello domestic?
yes I did notice, and yes I did reaim them. however, because you're now lower, if you angle your headlights up a bit so you can see anything on unlit backroads, on flat highways, the beams will go on forever blinding everyone.
Old Sep 22, 2005 | 12:00 PM
Tsx536's Avatar
Rep'n Taxbrain.com
I think most people lowered the front more than the back. So in theory the headlights would be pointing a little lower since the back head is raised up a little bit.
I haven't noticed it, but I only have aspec drop and I think that lowers the same amount on all 4 corners.
Old Sep 22, 2005 | 07:02 PM
TSX 3Pedal's Avatar
Did you reaim them yourself or did you take it to the dealership?
Old Sep 23, 2005 | 04:32 PM
xizor's Avatar
reaimed myself, its quite easy to do.
Old Sep 23, 2005 | 06:04 PM
madmanmax3000's Avatar
Professional Newbie
some instructions? I'm not sure how to do the HIDs
Old Sep 23, 2005 | 07:55 PM
xizor's Avatar
its pretty easy, search for detailed instructions. in short, open the hood, look directly down above each headlight. you should see a hole with a gear thing inside. if you stick a phillips head screwdriver into the gear and turn it'll raise and lower that headlight. you can also attach a socket to the back and turn that gear mechanism.
do the adjustment at night against a flat wall and make sure the 2 headlight beams match up to make a sharp line.
Old Sep 24, 2005 | 12:29 AM
BU's Avatar
BU
Thank You
1 more question
Can we adjust the Day-Time Running Light?
Bender
Old Sep 24, 2005 | 08:14 AM
Professional Newbie
guys LOL something hilarious happened last night. So I pulled up to my garage and turned on my headlights, looked at the level and raised them about 4 inches on my garage door. I was in a hurry to get outa there, so I headed out, and when i got on the road my headlights were as high as the trees!!! I felt like such a jackass and kept getting flashed at, but didn't have time to adjust them, guess i'm gonna have to do it this evening. Those things are BRIGHT when you aim them high
Old Sep 24, 2005 | 08:25 AM
mg7726's Avatar
She said: it's GINORMOUS!
^^ Lol!
Old Sep 24, 2005 | 08:27 AM
me_kevinly's Avatar
i would like to know are the beams uneven????
coz mine isnt a straight line
i tried to reaim it but its still unstraight and it took me two hr to kinda fix it! >.<
Old Sep 24, 2005 | 08:30 AM
me_kevinly's Avatar
i TOTALL understand what you mean LOL
it doesnt look much of a different in short distance
that why it took me 2hrs to fix it outside in the cold !
Old Sep 27, 2005 | 03:41 AM
S14 n Tsx's Avatar
mmmmmm....
ummm..yeah, that's right!! It's not post to be striaght line. The reason is the not to blind other drivers. It should look like this ________/------------- something like that.
Old Sep 27, 2005 | 05:34 AM
me_kevinly's Avatar
IC IC
DAMMIT @#%$323
and i spends hrs trying to fix it
and now i can get it back to stock angle >..<
Old Sep 27, 2005 | 05:45 AM
curik_euro's Avatar
Yohan
I think my Accord Euro has an auto levellingt feature on the HID. I was browsing through the manual and It says there is no adjustment required for one equipped with HID. And yes I do notice a slight reduction of visibility at night. I think the pro-kit drop is lower at the back, so I should lower the rear more to match the front.
Old Sep 29, 2005 | 03:11 AM
S14 n Tsx's Avatar
mmmmmm....
only way to know that your HID has auto levling is by turning your headlights on and see if light goes up and down. What is doing is adjusting itself to find the right angle and right height.
Old Sep 29, 2005 | 03:13 AM
S14 n Tsx's Avatar
mmmmmm....
IC IC
DAMMIT @#%$323
you should call the dealer and ask for what is the right height!!~
Old Sep 30, 2005 | 02:37 AM
ILoveMyHonda's Avatar
17781708
haha i did the same thing too...i felt like such a tool....luckily i had enough time to turn around and fix it
but to answer the question, yes i did re aim my headlights becuase the beams were lower after lowering prolly cuz I'm 1.2 F 0.75 R
Old Oct 4, 2005 | 08:42 AM
Errowen's Avatar
Car lust never sleeps
Autoleveling headlights are not available on any Honda/Acura vehicles.
The RL has "AFS" (Active Front Lighting System), which swivels the inside-turn HID in the direction of the turn, but this is linked to the steering wheel position, not to a gyroscope.
Old Oct 5, 2005 | 04:43 PM
rmpage's Avatar
Drives With Hands
Ahahah I finally found your post about this.
Old Mar 2, 2007 | 03:40 PM
dinoc's Avatar
My Euro CL7 Honda Accord 2006 has autoleveling HIDs and yes I'm concern if it's ok to lower the car safely ?
Anyone know if the autoleveling sensors are linked somehow to the suspension for this particular car ?
hashbrown
Feb 18, 2022 11:20 AM
Jul 16, 2017 07:33 AM
San Yasin
Sep 29, 2015 10:52 AM
rhdune16
Sep 28, 2015 11:31 AM
