Loud ticking from engine
Old Jun 27, 2005 | 05:08 PM
xizor's Avatar
Bye TSX, hello domestic?
I noticed probably 3 weeks ago my engine is ticking very loudly, enough that I can hear it in the cabin and feel a slight shake in my wheel like a rough idle. It happens at any RPM including idle. I've never over-revved the engine but do redline pretty often 1-2 and 2-3, heck I don't even have Hondata so I can only go up to 7300.
Any idea what it is? I wouldn't think I'd have a bent valve, or bad sparks as I have only 20,000 miles. I'm going to take it in and get it checked out, it only became noticable since it got really hot out.
x
Old Jun 27, 2005 | 05:53 PM
matelot's Avatar
Old Jun 27, 2005 | 09:02 PM
jmathew34's Avatar
x
possibly valve clearance issue, they may be out of spec...
hope its nothing serious, let us know how it goes...
Old Jun 28, 2005 | 05:19 AM
moda_way's Avatar
Check how much oil you have. Sometimes you'll get clicking from the valuetrain where oil is slow to reach it since there isn't enough.
Old Jun 28, 2005 | 09:24 AM
jlukja's Avatar
That was my first thought when I read your post.
Old Jun 28, 2005 | 02:16 PM
JTso's Avatar
Get a mechanic's stethoscope and point it to the cylinder head where each intake/exhaust runner meets the head while the engine is running. If the valves are loose, you can hear it very easily. Also, place the stethoscope on each fuel injector and see if the noises are from there, as they also make ticking noises. You can also place near anything that moves to track down the noise.
Old Jun 28, 2005 | 08:56 PM
xizor's Avatar
Took to the dealership today for an oil change and asked them to take a look at the ticking. After driving it around and listening to it w/ a stethoscope, the tech said its coming from the injectors but the sound isn't louder than other cars he's heard before so it might be they're dirty or just working hard w/ the 95% humidity we're having here.
I talked to him for a while and he was very intelligent, so I could swallow that the sound wasn't out of spec, just the injectors being loud. The car drives great, pickup is good, powerband is normal and gas mileage is fine, the injectors are just being loud. He said to bring it back if the sound is getting worse and he'll check it again.
Anyone know anything about fuel injector cleaner?
Old Jun 28, 2005 | 09:05 PM
mg7726's Avatar
She said: it's GINORMOUS!
chevron techron > *
i buy them bulk at costco and dump a bottle in every 5k-7k miles
Old Jun 28, 2005 | 09:11 PM
jmathew34's Avatar
i think you should upgrade to newer beefier injectors, to prep for the forced induction !!!
Old Jun 28, 2005 | 09:14 PM
xizor's Avatar
not yet at least, although I'll have the throttle body to do it. how much does bigger injectors affect gas mileage by themselves? my only measure is my friend's s/c'd prelude, granted he was suddenly making mad power, his gas mileage dropped into the teens even when not boosting everywhere.
Old Jun 28, 2005 | 09:33 PM
jmathew34's Avatar
i don't think changing the injectors out will affect gas mileage, i dont even think duty cycle of the injectors will decrease much....
JTSO might be able to chime in on this...where is he?!?!?!
Old Jun 28, 2005 | 10:48 PM
JTso's Avatar
Larger injectors controlled by the stock ECU will definitely have poor gas mileage and runs too rich. Just picture the ECU is programmed to fire the stock injectors for a certain duration and the amount of fuel injected is based on the injector size. If you replaced them with larger injectors and the same ECU is firing them for the same amount of duration, the engine will run rich.
Larger injectors are needed when runing FI setup but the ECU needs to be reprogrammed to trim back fuel during ide, or add fuel under boost condition. Otherwise, once the long term fuel trim (LTFT) has excessed a certain % of specification, it will trigger a CEL.
Laoch
1G RL (1996-2004)
Oct 2, 2015 03:27 PM
batheesha
Sep 19, 2015 09:51 PM
Sep 15, 2015 06:44 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
Hau_nguyen91
Sep 6, 2015 12:53 PM
