Loud noise when making sharp turns at low speeds
Good afternoon everyone,
I was hoping someone might have a little insight into a problem that my '05 TSX has been having lately. I went through the posts and couldn't find anything like it.
Whenever I make a sharp left hand turn at low speeds (about 5 mph or so), there is a loud creaking/squeaking type noise that sounds like it is coming from the left front tire area. I have never noticed it when making right hand turns. It doesn't do it all the time though. When I pick my wife up from work, I make the same turn every day into the parking lot and the car only makes the noise every 3rd day or so.
Just as an interesting observation, I did notice that my car has gone through some of the same problems that others have noted.
Steering wheel shaking during braking - new rotors
Passenger side door actuator going out - warranty
Condensation in headlight (3 times) - warranty
Any help on this recent development is greatly appreciated and any advice on problems that others have experienced that I should be on the lookout for as my car gets older (about 50k miles) would be great.
Thanks!
Thanks!
I had something that I would describe as sort of a "squeaking" sound when I turned full lock. My power steering fluid was low. I topped it off and the sound went away. you can check yours by looking at the reservoir on the passenger side of the engine compartment. not sure if this is the same thing though.
I've had the same metal creaking/clunking sound for as long as I've had my car, which is coming up on 3 years. I'm at 46k miles now. I can't tell if it's coming from a wheel or what, but it's from the front of the car somewhere. It happens at low speeds when turning, but not all the time. I had the dealer check it out, but they were unable to find anything. I've learned to ignore it.
Since I got an email saying someone had made a new post in the thread, I figure I'd come back and give a little update.
I took my car to the dealership a couple days after I made my post and they said they couldn't find anything wrong with it. I had checked the power steering fluid and it appeared to be fine. It hasn't made the noise for a while now. So I guess all I really had to add was... I don't know what the problem was.
The right front brake was also making a little squealing sound at low speeds. I knew it wasn't the wear indicator because I had just had the brakes replaced a couple months before and could see there was plenty of pad left. The dealer told me it could have been the fact that since I have after market rotors and pads they might not be lining up (those might not have been the exact words, but it was something along those lines) and there really wasn't anything to do about it. That sounded a little odd to me, but since I don't know a whole lot about cars, I took his word for it.
Anyone have any thoughts on that? My friend helped me install some Brembo rotors and Hawk HPS pads after we found out the original rotors were warped.
As always, thanks for the help.
Anyone check the clearence on your dirt shields on the backside of the rotor? Additionally, since you had your brakes replaced, have you verified that everything is install correctly and torqued (thinking the caliper could be loose)?
I have the same problem on my 04 TSX 5AT...
when I park at home or at the mall and I have to make a full right turn, I often hear a squeak like something is rubbing... I think it's the passenger side rear brake doing that... maybe the pads are rubbing because of the sharp turn???
ExcelerateRep
Sponsored Sales & Group Buys
Jan 6, 2016 09:59 AM
ExcelerateRep
Dec 11, 2015 12:58 PM
