Licnces plate light Covers
okay so i saw a couple of diys on how to install leds over the rear license plate. i dont wanna take off my trunk linear cause im having trouble removing some clips. does anyone know how to remove the covers from the outside
i changed mine this is what u do, when i bought my car under the mat i had a long peice of plastic about 6-7" and on the end it is wedged a little bit. im not sure if you have that but if you dont go to acura and they should have it. they are the 1's that actually helped me do it. now underneath where the licence plate light is, wedge the peice of plastic into the corner, until the clips come out, i was scared at first that i would break it but dont worry it wont crack, u do that to each side and your good to go. dont know if that helps. but it worked for me i changed mine 2 blue
Originally Posted by bo0sty
when you say mat you mean the trunk linear right?
and does that 6-7 in piece prevent the covers from being rmoved
no kidding.
how hard is it to unscrew and remove 3 clips?
it literally takes me less than a minute to do.
and it's the right way to do it.
I don't see the problem here.
do you not have a phillips screw driver?
if not, you shouldn't be considering any car mods.
turn the screws, pop out the clips.
peel down the top half of the trunk mat thing.
change bulbs.
reverse the clip procedure.
done, total, in less than 5 minutes.
it's honestly not hard at all.
don't be so scared of plastic clips, don't bother messing something up.
change bulbs.
yeah, it's a bit tricky at first.
they go in at an angle it seems, it takes a couple times to get the
hang of it so it's easy. just try them both ways, and give an angular
push, a light one. you'll hear it snap into place on one of the trys.
after a couple minutes you'll get it and it'll be easy from that point on.
like riding a bike.
like riding a bike.
cycdaniel
12-17-2019 10:58 AM
sockr1
10-01-2015 01:31 AM
wusty23jd
09-24-2015 11:41 AM
