I have a couple of problems!! Help Please!!!
Old Mar 17, 2009 | 04:38 PM
jliang39's Avatar
I just bought an 05 Tsx with 55k miles, and i have a few issues i would like to address and possibly find a solution to my problems!
1) I noticed when I'm driving downhill in cruise control, i feel the car 'hesitating' (in a slight back and forth movement). This slight back and forth movement would occur every 5-15 sec. Car recently installed new tires, new valve stems, 4 wheel balancing; i bought it certified from a dealership. Any clues?
2) I also noticed there is some 'leakage under the car. it feels like water, but i don't know. It is coming from a hole. Any clue what is going wrong?
Any help appreciated. thanks!
Old Mar 17, 2009 | 05:28 PM
808havok_tsx's Avatar
1. is your car an auto? if so, it sounds like the grade logic taking over. when the car senses its going down hill, it'll hold a lower gear longer to engine brake. this is normal and a built-in "feature". even if you were in SS mode and tried to upshift to a higher gear on a downhill, the ecu won't let you...
2. the tsx's a/c has the most ridiculous amounts of condensation i've ever seen. i'm talking a trailing river here. i had the same "problem" before but it ended up being the condensation...
Old Mar 17, 2009 | 05:38 PM
jliang39's Avatar
i have an automatic transmission. Does that mean i cannot do anything to mend these 'problems'?
Old Mar 18, 2009 | 04:52 PM
litesout's Avatar
Oliver!!!
Nope, they're not problems. They're like that by design. The grade logic control is there to help you keep your brakes from overheating on a long downhill grade. And the water is most likely condensation coming from the a/c. I get a pretty good puddle under my car too. But then I live in central Florida, so there's a wee bit of humidity here.
Old Mar 19, 2009 | 07:32 AM
troopa1's Avatar
its an over rev to stop the car from flying down the hill
cycdaniel
Dec 17, 2019 10:58 AM
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
DNS91
Sep 29, 2015 10:11 AM
jordanboi
Sep 5, 2015 01:33 AM
darknite123
Integra
Aug 30, 2015 03:00 PM
