Help! Shock? Strut?
Old May 30, 2005 | 11:35 AM
Howard911s's Avatar
HOWARD911S
Help! Shock? Strut?
front left side of my 04 has been making strange noise and bouncing more..so i took to dealer to get checked out. The guy told me the shock is bad. leakage they will have to order me new one. Now that I got home just saw the paperwork says verdict is LEAKING LEFT FRONT STRUT. NEED TO REPLACE STRUET-PARTS ORDER.
my question is..i know shock leaks.. but does strut leak?
why he said SHOCK broken but on the paper typped STRUT?...
.if it is either shock or strut..do i need to insist that they replace both? and will I need alignment after replacing both or either one?.....
Old May 30, 2005 | 11:57 AM
sauceman's Avatar
Moderator Alumnus
Two different expressions for the same thing. All is well.
Moving to Problems and Fixes now.
Old May 30, 2005 | 12:04 PM
scl23's Avatar
Goldmember
Yeah, I think I have the same thing. I ran over some road debris and now my tires rattle when coming to stop sometimes. I have 500 miles. Is this covered by warranty or do you have to pay for the fix?
Old May 30, 2005 | 04:20 PM
Howard911s's Avatar
HOWARD911S
your tire rattle? or your steering wheel rattle when u stop? if u hit a debrie hard when braking. u may warp the rotor. resulting in steering wheel rattle when trying to stop. it would be covered
Old May 30, 2005 | 05:14 PM
scl23's Avatar
Goldmember
no my tire rattles like the struts are blown or something. But the springs still seem to be fine.
Old May 30, 2005 | 06:07 PM
Howard911s's Avatar
HOWARD911S
eh..........i suggest u go get it checked out asap...
Howard911s's Avatar
HOWARD911S
and yes. its absolutely under warranty. unless u modified something the it would void it. but they anticipate daily wear and tear. so it will be under warranty
Old Jul 27, 2005 | 08:54 PM
castillo183's Avatar
that is the same problem that i have to every time i hit a bump i hear nosies coming out of the left? you think you might know what is the problem and it got worst when i drop the car down to 1"
Usmcgrunt47
Oct 13, 2023 09:35 PM
Jul 16, 2017 07:33 AM
lanechanger
Oct 13, 2015 10:56 AM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
