Help! Car didn't start
Old Jan 22, 2008 | 05:58 PM
supraken's Avatar
Ok, so I'm not sure if this was just a freak thing, or something's wrong. Today I went to a local store, and when I got back to my car to try to start it as usual, something weird happened.
I turned the key to ACC, everything was normal, then when I try to start it, everything (I mean EVERYTHING including the dome lights, gauges, etc) turned off, leaving only the VSA, (!), and ABS lights on. Let go, crank, nothing. Then it seems like the whole car has no power.
Then I proceed to pop the hood, and wiggle the battery cables, fuses in the fuse box. Dome lights came back on sometime during this, I tried to start the car again, ACC, all gauges light up, turn key, everything went off again.
I wiggle the cables and fuses some more (couldn't think of anything else to try before calling someone for a jump start), went back in car, then the car started.
What could this be? If it was a loose battery connection, I don't think ONLY the VSA, (!), and ABS lights will be on. On the other hand, if it was a loose fuse, why would everything else be off?
Also, I noticed a electrical burning smell when I was driving to the store, but I couldn't tell if it was coming from the outside of the car while driving. However, when I found out the car didnt' start, I kinda smelled it (maybe a mental thing).
Old Jan 22, 2008 | 06:05 PM
JayRoam's Avatar
this used to happen to me when my old non-OEM floormat got in the way of the clutch. Maybe your clutch wasn't depressed all the way for some reason? I think you can replicate everything that happened by turning the key without depressing the clutch. Hopefully it's just that simple.
Old Jan 22, 2008 | 06:06 PM
JayRoam's Avatar
this is assuming of course that you have a 6mt. if you're 5at, i'm at a loss?
Old Jan 22, 2008 | 07:19 PM
supraken's Avatar
Yeah, unfortunately, I have a 5AT.. It did seem like some sort of ignition disable mechanism was in play, but I am not sure...
Old Jan 22, 2008 | 07:42 PM
visuelz's Avatar
East Coast Crew
It might just be the immobilizer. Happened to me back then. It just went away.
Old Jan 23, 2008 | 07:27 AM
miner's Avatar
will your headlights come on before starting? If they are dim, battery is close to dead.
Old Jan 23, 2008 | 08:39 AM
supraken's Avatar
They come on no problem, assuming I don't get that situation where nothing comes on except the VSA, (!), and ABS lights. Battery is less than 1 year old.
Old Jan 23, 2008 | 08:42 AM
LukeaTron's Avatar
HIDs won't be dim. They'll either come on or not at all. If the battery has just barely enough juice to start the HIDs they'll sometimes cycle on and off very quickly. The stock battery is a puny and if it's a year or two old, it just might not have enough juice in this cold weather we've all been having. It's caused problems for a number of people.
The burning smell is disconcerting though.
Old Jan 23, 2008 | 01:02 PM
nbtx's Avatar
still plays with cars
Classic dying battery problem. Its internal resistance is too high to provide cranking current which is about 200-300 amps. Take it to your local Advance Auto/AutoZone/etc. for testing.
orkoTL
4G TL Problems & Fixes
107
Sep 28, 2017 09:12 AM
bearingman07936
Jan 7, 2016 03:22 PM
andysinnh
Sep 5, 2015 11:38 PM
jordanboi
Sep 5, 2015 01:33 AM
dlknight
Sep 3, 2015 07:54 PM
