Help! - Brake Issues
Old Sep 10, 2006 | 11:38 PM
str8 tsx's Avatar
This just started happening. When I brake with medium pressure I can feel slight vibration and grinding from the front brakes? Does this mean my pads are worn out? I'm at 19k and I'm in constant stop-go traffic everyday in SoCal. What's the problem here? Thanks in advance!
Old Sep 10, 2006 | 11:47 PM
Distortion's Avatar
Walking the Line
Sounds like warped rotors. Happens often on new TSX's. Try to get them replaced under warranty if that's the case or you can take this chance to upgrade the rotors and pads.
Old Sep 11, 2006 | 12:02 AM
acn684's Avatar
hrm..my breaking has been a bit jittery too. I also get this annoying squeal when i first drive the car...dammit...gotta go check that out...
Old Sep 11, 2006 | 01:30 AM
str8 tsx's Avatar
So if this happens often on TSXs, how will replacing them under warranty fix the issue? Won't they warp again eventually is it's the same part? Does that mean Acura is using inferior rotors/braking components?
Old Sep 11, 2006 | 02:35 AM
kboosman00's Avatar
no0bIe
^ Yes, they will occur again. Your best bet is to upgrade your rotors to UP racing brake rotors w/ hawk pads, I've gone this route and haven't had a problem since. Mind you that I did have my rotors resurfaced 3 times before I got tired of going back to the dealership. It was the best upgrade I could have ever done to the TSX.
Old Sep 11, 2006 | 07:53 AM
CGTSX2004's Avatar
Search for "vibration" or "shudder" or "brakes" and you'll find plenty of threads discussing this issue and what can be done to fix or adapt to it.
mada51589
Jan 9, 2025 04:40 PM
HOWELLiNC
Sep 10, 2015 01:39 PM
jliu6789
Sep 8, 2015 08:02 PM
mav888
1G RDX (2007-2012)
Sep 8, 2015 11:49 AM
nishant11
Sep 2, 2015 10:34 AM
