Help! - Brake Issues
This just started happening. When I brake with medium pressure I can feel slight vibration and grinding from the front brakes? Does this mean my pads are worn out? I'm at 19k and I'm in constant stop-go traffic everyday in SoCal. What's the problem here? Thanks in advance!
Walking the Line
Sounds like warped rotors. Happens often on new TSX's. Try to get them replaced under warranty if that's the case or you can take this chance to upgrade the rotors and pads.
no0bIe
^ Yes, they will occur again. Your best bet is to upgrade your rotors to UP racing brake rotors w/ hawk pads, I've gone this route and haven't had a problem since. Mind you that I did have my rotors resurfaced 3 times before I got tired of going back to the dealership. It was the best upgrade I could have ever done to the TSX.
mada51589
05-03-2022 08:54 PM
