Fog Lamps
Old Aug 23, 2005 | 08:48 PM
Adrena's Avatar
Fog Lamps
Just a quick question.
Got the fog lamps installed today, but they only turn out when the HIDs are on... They stay off with running lights, even when the switch is on ...
Same for everyone?
Old Aug 23, 2005 | 09:06 PM
cmf's Avatar
cmf
ATCer
Yep, only work when headlamps are on.
Old Aug 23, 2005 | 09:49 PM
BDI's Avatar
BDI
yup
Old Aug 24, 2005 | 10:14 AM
barbeau82's Avatar
People call me Butterbar
I'm sure there's a "fix" for this, search the FAQ section.
Old Aug 27, 2005 | 08:13 AM
dmbfan36_23's Avatar
They also turn off when the highbeams are on.... these are exactly how my OEM Fog lights function...
Old Sep 22, 2005 | 01:07 AM
sevans28's Avatar
Does this mean that there is no way to just have the headlights on (regular, no hi-beam) without the fog lights? So no matter what the case, oncoming traffic will see the white light from the headlights, and the yellow lights from the fog lights? If so that seems like such an aesthetic dissapointment. This question is more geared to the upcoming '06 model.
Old Sep 22, 2005 | 01:41 AM
S14 n Tsx's Avatar
mmmmmm....
I think there is way to do it. You gotta do some re-wiring!~ For example, samething goes to my 240sx. I have fog lights and they only come on when headlights are on and when hi-beams are on they go off. I seen people re-wire so when their parking lights are on they(fog lights) comes on at the same time.
Old Sep 22, 2005 | 08:29 AM
TSX.Fury's Avatar
send me a link to JDM??
you can turn off the fog lights any time you want. There is still a fog light switch. However, you can't have the fogs and highbeams on or just the fogs on.
Old Sep 22, 2005 | 03:11 PM
Mokos23's Avatar
There is a fog light switch and like others above have said you can't just use the fog lights indepent of the HID lights.
The same concept has gone with the last generations of Accords.
Old Sep 22, 2005 | 03:15 PM
Motohip's Avatar
I'm a llama :(
That's always been the case with all honda's that have had a factory fog light option.
Even the del Sol was the same with the aux lights except it still worked with the highbeams on I believe.
Just pull out the button, cut the "hot" wire, take the wire that's still attached to the button and wire that to a wire that's hot with the ignition in either "Acc" or "on."
Old Sep 22, 2005 | 07:25 PM
acn684's Avatar
oh really theres a switch with the fog lights? cool. I'm getting an 05 soon with oem fog lights, wheres the switch?
Old Sep 23, 2005 | 07:32 AM
On the light control arm (left side of the steering wheel) there's a ring for the fog lights.
Avenger411
Oct 11, 2015 03:53 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
rockyboy
Sep 29, 2015 12:05 AM
rhdune16
Sep 28, 2015 11:31 AM
Eggs999bacon
Sep 24, 2015 10:08 AM
