Engine code P0957
Old Jan 29, 2009 | 05:09 PM
Superb0o's Avatar
Engine code P0957
So, I drive an 05 auto TSX and it threw up an engine code P0957 "Auto shift manual circuit low".
It's in stored and not pending. should I be worried? or should I just delete it?
This is the first strange code that I've ever gotten. I don't count the one I get when its super cold because of my RT cat.
Thanks!
Old Jan 29, 2009 | 06:22 PM
valeratj's Avatar
Unregistered User
off topic question: any issues with RT cat in our communist-emission state?
Old Jan 29, 2009 | 10:16 PM
Miamicarfan's Avatar
superb0o: How do you know the engine is throwing a code? Did a light light up in the instrument panel? If so, which one?
Old Jan 29, 2009 | 11:20 PM
Superb0o's Avatar
Well, I haven't had to smog the car, but I do have a virtual emissions checker using pcmscan for my computer. Long story short, I fail but I have my stock cat still so if I need to, I'll just switch it out.
Old Jan 29, 2009 | 11:23 PM
Superb0o's Avatar
I know my engine is throwing a code because the light came on and I checked it using an OBDII software that I usually use. It's the check engine light that came on, the pipe looking thing. But I read all of the codes, and the code read what I previously said.
I think I'm going to just take it to the dealer tomorrow like the manual says.
Old Jan 29, 2009 | 11:35 PM
LukeaTron's Avatar
I did some hunting around and I think this is some kind of electrical fault in the transmission or it's control circuitry. Definitely dealer territory.
Old Jan 30, 2009 | 12:05 PM
Superb0o's Avatar
that sucks. Thanks for the info...
Old Jan 30, 2009 | 12:24 PM
poltergeist's Avatar
P0957 indicates a fault in the "Sportshift" selection switch, or it's circuit to the PCM. The switch is mounted to the shifter assembly on the left side under the console. Most likely cause I've seen for codes like this is something getting spilled (coffee/soda etc) into the shifter and leaking into the switch. It's a fairly simple switch (actually two in one assembly), an on/off switch activated when the shift lever is moved in/out of "Sportshift" mode, and a 3 position momentary switch for up/downshift commands from the shift lever. Easy to test with an ETM.
Yikes
May 3, 2021 04:29 PM
ghuns
Sep 16, 2015 04:26 PM
datadr
Sep 12, 2015 09:12 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
