aftermarket alarms
Why, are you having problems? The only problem I have with my Viper 5900 with remote start is that I don't have a safety neutral switch cause all of the installers I encounter doesn't know how to install it. Other than that I lose memory seat and automatic window roll down, which I can live without.
No problems at all. Tested just about everything there is and the pager shows clearly what's been tampered.
well with my alarm...when i got it installed...the hfl and drivers side fuse box went bad...and so did the drivers side window switch...so i dont know if it cause those to short out or not. basically at first there was a 1 amp draw on my battery. then the hfl and fuse box were replaced after that was fixed there was only a .5 amp draw. then i had to remove everything on my car that was not factory. which one of the things was my alarm..so i did that then they tested it again and found the switch was bad and got the draw problem fixed. so then i took my car back to get the alarm put back in and the draw came back up to .59 amps.
Jul 16, 2017 07:33 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
