ECM Relay location
Old Oct 18, 2008 | 10:27 PM
DavidIQ's Avatar
Question ECM Relay location
Car got plugged into one of those code readers the other day due to some strange engine problem (seems electrical) and came back with an ECM Relay problem so I ordered one along with a doorlock actuator that we needed ($20). Figured it's just a relay so I can switch that out easily...right? Well...I can't find where the ECM relay is actually at to change. Anyone know where it's at? I was thinking it would be somewhere in the engine but it's not in the fuse/relay box.
Old Oct 19, 2008 | 09:58 AM
poltergeist's Avatar
The PGM-FI Main Relay 1 (which powers up the PCM, among many other circuits) is in the underdash fusebox. It's the middle one in the top row of relays.
Old Oct 19, 2008 | 12:58 PM
DavidIQ's Avatar
You mean the fuse box that's just above the hood popper? Checked in there...there's nothing but fuses. Is there another fuse/relay box somewhere under the dash that I'm missing?
Old Oct 19, 2008 | 01:00 PM
JTso's Avatar
poltergeist said "underdash fusebox".
Old Oct 19, 2008 | 01:02 PM
DavidIQ's Avatar
Hmmmm...then the question really is where's the underdash fusebox? How do I get to it?
MMsTSX's Avatar
JDM Addict
driver's side kick panel probably.
Old Oct 19, 2008 | 01:08 PM
DavidIQ's Avatar
If that's the compartment that slides out with all of the fuses inside then there's nothing but fuses there...it must be somewhere else...a box that's not documented in the owner's manual.
Old Oct 19, 2008 | 01:10 PM
MMsTSX's Avatar
JDM Addict
there's more than just fuses down behind that kick panel.
if you had a service manual or an ETM, you would have all the
diagrams and information that you would need.
Old Oct 19, 2008 | 01:16 PM
MM's correct, you'll likely have to remove the kick panel for access, but there are 6-7 relays plugged into the fusebox. BTW, what code was stored, and did you actually diagnose that the relay has failed? (I'd guess you didn't test it if you haven't found it).
Old Oct 21, 2008 | 03:20 PM
DavidIQ's Avatar
Nope...haven't tested it. Figured since it wasn't expensive I'd just buy it and replace it.
I'll take the kickpanel out and take a look. Thanks guys.
Old Oct 21, 2008 | 07:49 PM
240sx acura tech's Avatar
acura master tech
i would real like to know the code if you have it.
Old Jun 3, 2016 | 10:05 AM
Sasha Colon's Avatar
ECM code
the code for my acura tsx 04 is P0685 i will like to know is that the relay or its something major. The car runs fine it just turns off wherever but it will turn back one
Old Jan 3, 2019 | 08:07 PM
Hector Ruiz's Avatar
P0685 code on my 04 tsx
seen you have the same issue as i do now in 2019!! I took the car to dealership and they couldnt figure shit out! I ended up getting a new ecu and reflashed by hondata! Still doing the same issue! Did that relay fix it for you?
Old Aug 26, 2023 | 08:53 PM
702Razz's Avatar
5th Gear
Did you get this fixed? please let me know. I have the same issue on a 2005 acura TL, it was overheating because the fans would not turn on. Now it shuts off while driving and has a hard time starting most of the time now. Below is what has been done so far.
It seems the dealership fixed the fan issue, but they weren't able to fix the car shutting off issue. It shuts off while driving.
I tried changing the fuel pump relay. The fuel pump relay that has recall. I want to know what to do before I spend money on a new fuel pump or on the E. C. U./. E. C. M. main F1 Relay. From the diagram on the bottom of the plastic cap the blue relay I had switched is the fuel pump relay, the brown relay is the ECU relay and that's the code I get p0685. The dealership changed the ignition switch and charged me for that. Set the problem was fixed. However, it was not. It took five days for them to look at the car. It's 6 days for them to quote Unquote, fix it. But it was not fixed. It was a Honda dealership, but the Acura dealership is further in my car. Keeps shutting off, so it's not safe to drive that far. It seems to shut off after being on for about. 40 seconds to a little under two minutes.. The battery test fine. I charged it and in the past autozone charged it when I test it. It's at 12.3 to 12.4 volts. without the car running. there is this Type of wire assembly that hangs on the crossbar. the the big metal bar that goes from your struts on top. of your wheels in the back near the firewall of the engine bay. It seems I had forgot but to screw back on and it was just dangling back there and it must have been back there when the car overheated. Does anyone know what that thing does? It goes to the fuse box and the engine bay..
Old Dec 21, 2024 | 02:52 PM
HotboyTl07's Avatar
3rd Gear
It's on top of them fuses in car
Jamus22
Jun 11, 2023 10:08 AM
vpasla1
Sep 17, 2016 07:24 PM
MetalGearTypeS
Aug 29, 2016 08:28 PM
malvothegreat
2G CL Problems & Fixes
Sep 29, 2015 08:00 AM
greeneyes.hypnotize
Sep 27, 2015 02:47 PM
