Auto tranny shakes at certain RPMs
Hey everyone. Recently bought a 2008 TSX with 107k miles. I have put about 4k miles on it since buying it in August of 2024. I have noticed when driving that the transmission will struggle sometimes when RPMs hover around 1600 and low speeds. It seems to do fine above and below this RPM. The best way I can describe the feeling is similar to when a manual transmission is too low of RPM and so it bogs causing the driver to change downshift.
Has anyone else experienced this issue? I still want to change the transmission fluid. Are there any upgrades I can do to the automatic transmission?
For transparency I have replaced the following since I have bought it.
New front rotors and pads
New stainless brake lines for front
New spark plugs
2 oil changes Mobil 1 5w-30 Full Synthetic
New VTEC solenoid gasket
Rotated tires twice (at both oil changes)
New alternator
New belt
New tensioner pulley
Any help would be appreciated. Thank you!
New spark plugs
New alternator
New belt
New spark plugs
New alternator
New belt
New spark plugs
New alternator
New belt
You mention a good list of work performed on the car but nothing related to the transmission. I would check the level and perhaps consider a transmission fluid change.
Beyond that you could be into something engine related (air filter, fuel filter, clogged injectors, VTC system issues, etc).
Hi,
