Driver's side rear window won't roll up from master window control.
Old May 30, 2019 | 03:41 PM
tbrig1's Avatar
In my 07 TSX, I noticed recently that the rear driver's side window won't roll up from the master control. Usually, there's a pretty audible click noise to let you know that the window motor is being engaged to roll the window up. Right now, I only hear that when I roll the window down.
At the right driver's side window control, I can roll the window up and down no problem. I've tried replacing the master window switch, I've checked the fuse and tried swapping it with the rear passenger side window fuse and there was no change.
I'm not sure what to check next, I was able to roll up the window from the master control switch a couple of times when I opened up the driver and rear driver side doors. I was thinking this perhaps has to do with the link that goes through the pillar between the doors? Not sure.
Any advice is appreciated. If there's a better place where people talk about these kinds of things, I'd also be interested in that. Thanks!
dubz ASPEC
Jun 3, 2025 08:48 PM
mellsonnj
3G MDX (2014-2020)
Nov 4, 2016 07:35 AM
unoo
1G TSX Problems & Fixes
Apr 29, 2011 05:02 PM
chayos00
Oct 18, 2010 07:51 PM
playboyace35
Oct 18, 2006 10:08 AM
