Door Lock Problem (Sticking)
Old Oct 13, 2005 | 07:59 PM
xLusi0n's Avatar
So out of nowhere, my 2004 5AT W/O NAVI's door lock developed a sticking problem.
1) Using the remote, the DRIVER door will stick (not lock or unlock)
2) Using the key = no problems
3) Problem exists also when using the unlock/lock button on the door
Will be bringing back to dealer tomorrow...hopefully easy fix.
Old Oct 14, 2005 | 02:08 PM
LoveMyTL-S's Avatar
Battery low in remote?? Have you tried the other remote?
Old Oct 16, 2005 | 03:26 PM
xLusi0n's Avatar
It's not remote cause it has the same problem when I use the door button. I took it in already and it needs a new door actuator (or watever that thing is that controls the locks). Using the key is mechanical which is why it's not effected. Should be fixed Monday
Old Oct 16, 2005 | 06:09 PM
dowzer's Avatar
Whoa, this is the same problem I've recently started to experience. Glad to know I'm not alone.
I found that if I lock/unlock the door with the remote or power lock switch a few times, it "unsticks" itself. But if I let it sit for a couple of minutes, it starts again. Did you notice this on yours as well?
Old Oct 18, 2005 | 08:51 PM
xLusi0n's Avatar
Dealer fixed it! My problem occured all the time.
Dealer replaced the actuator.
Old Oct 6, 2006 | 09:19 AM
Black_6spd's Avatar
VSA Rocks
Just got the power lock "sticking" this morning as well. The only way I can lock and unlock my door is with the key or by pulling up the manual switch.
The dealer has to replace the actuator?
Old Oct 6, 2006 | 09:41 AM
godfather2's Avatar
Time to Climb
i thought i was on my own as well ... i wonder how many people are affected?
Old Oct 6, 2006 | 09:49 AM
pr0tek025's Avatar
I have similar problems on my 05. I'll be making a stop at the dealership on Monday.
Old Oct 6, 2006 | 09:52 AM
wickedk24's Avatar
Oh well it's
Happen to me a couple of months back too, it was the actuator that needed replacement. Good thing it was still under warranty.
Old Oct 6, 2006 | 10:03 AM
Black_6spd's Avatar
VSA Rocks
Whoa -- three replies in less than an hour??
I was expecting a reply within the next week or so! I wonder how widespread this issue is?
<-- going to the stealer tomorrow.
Old Oct 6, 2006 | 10:19 AM
PACman's Avatar
Happened to me too back several months ago. Got the actuator replaced and now working like new.
Old Oct 6, 2006 | 12:31 PM
Tsx536's Avatar
Rep'n Taxbrain.com
Happenned to me too man. It was my F passenger side.
I got it fixed under warranty. I'm out of warranty now though
Old Oct 6, 2006 | 02:20 PM
TSX 3Pedal's Avatar
Use all 3 Pedals at once
...if it wasn't covered under warranty, how much would it be out of pocket?
Old Oct 6, 2006 | 02:47 PM
PACman's Avatar
Unfortunately, I was out of warrantee when it happened. I think my bill was $250 (parts & labor). The actuator was cheap...$35. It was the labor that got me.
Old Oct 6, 2006 | 03:24 PM
Black_6spd's Avatar
VSA Rocks
Jeez. Mods - can you turn this into a poll so we can get a count?
The thing I absolutely HATE about bringing my car to the dealer is the attention it draws. As soon as I pull up, the service advisor usually says, "Whoa -- SIX SPEED?? I don't see any of those around here!" It gets worse when my car pulls up in the service bay and the mechanics finds out it's modded.
Later on, I check up on my car and they'll say, "Oh -- they took it out for a road test to make sure everything is OK."
Yeah right. All I wanted was an oil change. And why did they need TWO people for the "test?"..
Tsx536 probably is a bigger target at the stealer due to his s/c setup.
Old Oct 6, 2006 | 10:37 PM
ncsu-tc's Avatar
I had the same problem on my pass door. The dealer took care of it under waranty
Old Oct 6, 2006 | 11:22 PM
supraken's Avatar
+1
Had it happen on my driver's door a few months ago. I thought it was because of all the extra insulation I put into the door. Dealer replaced actuator...
I didn't know THIS many ppl experience the same problem. I guess a batch of poor quality actuators.....
Old Oct 7, 2006 | 12:00 AM
kboosman00's Avatar
no0bIe
Add another check to the list, I too had this occur in my TSX as well.
Old Oct 7, 2006 | 01:18 PM
dowzer's Avatar
Mine finally died 2 weeks ago. The dealer ordered a new actuator, but I'm still waiting for it to come in. Not having the keyless entry is pretty annoying.
Old Oct 7, 2006 | 03:14 PM
Tsx536's Avatar
Rep'n Taxbrain.com
Dang $250? Since I'm out of warranty, if one of my other door locks go I'll probably just buy the part and do the labor myself.
Although my dealer did just cover something for me under warranty the other day eventhough I was at 57K miles.
Old Oct 7, 2006 | 03:24 PM
Tsx536's Avatar
Rep'n Taxbrain.com
I know what you mean. My service advisor is a friend of a friend so that helps a little bit, but still. I took my car in last week and I made sure to reset my Trip B meter right when I dropped it off. I also usually tell them that I'm going to stay and wait for the car even if I'm leaving.
Then I walk by the service bay and do the whole Robert De Niro, "Hey, I'm watching you Focker" eye/hand motion from Meet the Parents to the Techs.
Old Oct 8, 2006 | 11:38 PM
pizzaman555's Avatar
My front passenger one died on my 05 TSX.
Old Oct 9, 2006 | 12:50 AM
nahooneyya's Avatar
A Commuter
this also had happened to me about a month ago on the passanger side, and of course it was fixed right away by the dealer.
i have 04 btw..
Old Oct 11, 2006 | 09:31 PM
kaliraver69's Avatar
I took my car to the stealer and they have to order a replacement actuator on my front passenger door. It just had died last night. Good thing am under warranty so I will pay nothing out of pocket.
Old Oct 11, 2006 | 11:03 PM
feelgood13's Avatar
anyone know if there is a screw or something to adjust the doors so it can swing a little easier?
Old Oct 12, 2006 | 06:48 AM
moda_way's Avatar
Find door hinge, add grease.
Old Oct 12, 2006 | 12:23 PM
Black_6spd's Avatar
VSA Rocks
Just got mine replaced yesterday. I guess some dealers keep the actuator in stock. I dropped my car off in the morning with Thomas Acura in Covina and was able to pick it up during lunch.
The first thing I noticed was the lock was making a much quieter 'click' rather then the 'clunk' it previously had since the car was brand new.
Anyone know if the actuator has been changed to a different design and part number?
<--- Looking it up
Old Oct 12, 2006 | 12:33 PM
Black_6spd's Avatar
VSA Rocks
Looks like the part numbers for the actuator assembly on both the 05 and 06 models are identical. The TL shares the same actuator design as well as does the Accords.
Whoever is the supplier on this designed dropped the ball. This is the first Honda 'failure' I've had under warranty. At least it was minor issue...
Old Oct 22, 2006 | 12:45 AM
SF_TSX's Avatar
Mine gave up on me today. How many of you had to wait for the part come in?
Old Oct 22, 2006 | 01:20 AM
Eeyore's Avatar
Registered Abuser
Wow this thread is amazing. As of a few days ago my driver's side door will not unlock with the remote. I'm still under warranty so I'm planning on bringing it into the dealer. I try to avoid the dealer as if they had the plague. Oh well.
Old Oct 22, 2006 | 10:58 AM
dowzer's Avatar
My dealer had to order the part in, but after 2 weeks I still didn't get a call from them. So I dropped by and discovered that the part actually came in after a couple of days, but whoever entered my case into the system screwed up because they couldn't find the record in the system.
It didn't actually surprise me, since I don't have much confidence in some of their reps. In any case, they put the part on that same day and the lock works like a champ. Managed to test drive the RDX and new MDX while I was waiting.
Old Oct 26, 2006 | 06:20 PM
palidanx's Avatar
honk not beep
gees.. mine just died today... hopefully they have actuators in stock
Old Oct 29, 2006 | 12:18 AM
feelgood13's Avatar
are actuators the same as solenoids?
Old Oct 29, 2006 | 05:24 PM
NJTSXMan's Avatar
Add me to the list.. My passenger side door lock is sticking as well as of today. I was like.. WTF. I guess i have to make an appt with the dealer.
Old Oct 30, 2006 | 10:40 AM
scsptgtsx's Avatar
Add me too....but with a new twist. At the same time the driver door lock started sticking, the center display for the radio and climate control died. The radio still works, just can't see anything in the display. I checked fuses and even replaced battery when Mr. Auto Zone said it tested low...and no help. Strange coincidence...both problems at the same time?? Anyone else have this? I was glad to hear I wasn't alone with the door lock problem.
Old Oct 30, 2006 | 11:45 AM
803Twon302's Avatar
My drivers side has been acting up for about a week now. The dealer is an hour away so I'll probably have to deal with it until I can get time to take it in. If the actuator is the problem I'll probably pay for the part and just handle the labor on my own. This is a great thread!
Old Oct 30, 2006 | 04:15 PM
NJTSXMan's Avatar
I noticed this my morning that my driver's side lock was sticking in addition to the passenger side lock.
Old Nov 26, 2006 | 05:35 PM
alpinestar's Avatar
TS-SEX
My driver side lock started to stick today as well. If anything does happen to change the actuator themselves, can they post up a DIY of the process? (In case my warrenty is up already, I have an 04')
Old Jan 13, 2007 | 09:00 PM
gfd1182's Avatar
My driver side door lock started stickin today. Thanx to this thread I now feel at ease knowing what the problem is
They should really fire the company that developed this actuator
Old Jan 20, 2007 | 03:07 PM
mjrchaos's Avatar
The Driver side auto door lock on my 04 TSX w/Navi stopped working at 24,303 miles. The dealer replaced the actuator when I came in for an oil change -- all in the same visit. Thankfuly they had the part in stock.
