Condensation in Headlights
Old Mar 2, 2006 | 02:20 AM
  #41
fuckleberry's Avatar
Originally Posted by hawaiiantsx
when i had mine changed out, they said they couldnt give it to me because they had to send it back.But, when i talked to my friend who use to work at the acura dealer....he said they only throw it in a back room and after 90 days....they only throw it away.....go figure
yeah,
of course they don't send that thing back.
The frigging manufacturer (Stanley) is in Japan. That's just BS they give.
I got a pair from eBay in excellent shape for $100. Those "defect" are totally worthless. (To dealer & Honda)
Old Mar 2, 2006 | 06:47 PM
  #42
l7h8626's Avatar
Team Hybrid
i just noticed that my passenger side headlight got foggy after driving in a heavy rain few weeks ago in so cal...
i know it sux but i think i wont bring the car back to the dealer and get it replaced...
cuz i already have my JDM lights sitting in my garage over a month... time to put them on =)
Old Oct 23, 2006 | 09:04 AM
  #43
jiggaman's Avatar
I spend 2 much time here
head a tiny patch of fogging in my passenger side brand new jdm headlights last night...it went away after sitting in the garage for a bit. ugh
Old Oct 23, 2006 | 11:28 AM
  #44
jwood_06TSX's Avatar
Had the same thing saturday night happen. It got really cold and i came outside from bowling and there was a large patch of condensation in both my front headlights but went away the next day.....uugghh, now i have to go back to the dealership!
Mine aren't brand new JDM ones though....that stinks jiggaman
Old Oct 23, 2006 | 11:37 AM
  #45
jiggaman's Avatar
it was just a small patch and if thats the worst it ever gets i can live with it. i threw in another silica moisture pack though just in case.
Old Oct 23, 2006 | 11:40 AM
  #46
aren't the JDM lights covered by a warranty though too regardless of where you bought them?
Old Oct 23, 2006 | 12:03 PM
  #47
I just called the dealership and told them about my headlight condensation and he set me up with a rental car for next tuesday to have it fixed under warranty!
I will highly recommend Davis Acura to anyone in the area, these people have been great to work with so far in dealing with issues i have with my car. They are just expensive if you need to get other things taken car of there!!!
Old Oct 23, 2006 | 06:06 PM
  #48
PJS's Avatar
PJS
Another one with Honda Accord (European TSX model) - even though it's out of warranty, I think I'll be speaking with Honda about this. Good to see Acura or their dealers setting a precedence with swapping them out.
There's no way headlights in this day and age should fog up with condensation.
Old Oct 23, 2006 | 07:32 PM
  #49
curik_euro's Avatar
Yohan
does it condense only when you wash the car or when it rains before? Mine doesnt come up with such a thing
Old Oct 23, 2006 | 07:51 PM
  #50
PJS's Avatar
PJS
Mine condenses like windows do - temp differential.
They also look filthy on the inside - dusty. Could do with a damn good clean, but that's the first headlights I recall seeing like so. Next time it happens, I'll take a photo and post it up so you can see.
It's not pretty, I warn you in advance.
Old Oct 23, 2006 | 09:45 PM
  #51
jiggaman's Avatar
so far mine aint bad, only seen it happen once and was a tiny patch on one headlight. i'm hoping that i wont see it again. tomorrow i am going to go to the touchless carwash again to see what happens. thats a good test for leaks...
Old Nov 5, 2006 | 07:57 PM
  #52
morpheus's Avatar
my driver side headlight has condensation. the headlight itself stopped working now. i didn't see others mentioning about headlight not working. Is it common?
To answer some other query on the thread, it is raining continuously here in seattle. and the problem seems to be because of that.
Old Nov 5, 2006 | 08:05 PM
  #53
felixthekat's Avatar
Meow.
For me, condensation has gotten into both sides of my headlights. In one of the the bulb actually shorted because of the condensation. But Thomas Acura replaced it with no problems. Just take it into a dealer. It'll take about like 3-4 hours to fix.
Old Nov 9, 2006 | 10:59 AM
  #54
ASpecTSX's Avatar
I had condensation in my drivers side headlight and didn't think much about it at first, but then the condensation was shorting out the HID causing it to malfunction from time to time so I took it into the dealership. They replaced the entire headlight and it worked fine when I left the dealership, but then the light shorted out again that evening. I took it back in a couple of days later and they ended up replacing the HID assembly and I haven't had a problem in the 8 months since then.
Old Nov 10, 2006 | 04:50 PM
  #55
jiggaman's Avatar
man it seems like when the temperature goes from warm to cold outside is when i get some fogging in mine. worst part about it is these are with my $600 JDM headlights.
i seem to have the worst like in the world when it comes to modding my car. nothing every goes easily. it wasn't even raining today so there must be moisture inside the headlights. i opened up the section for the high beams and aimed a hair dryer in their for a couple minutes to dry out the fogging and closed it up again. hopefully that will be the end of it. all the seals "look" fine.
headlight mods definately go on my list of better off left alone...my original headlights never fogged up once in 3 years of ownership.
Old Nov 10, 2006 | 10:42 PM
  #56
Tsx6363's Avatar
Originally Posted by GeorgeTSX
Here is what I posted about this issue almost a year ago...
http://www.acura-tsx.com/forums/showthread.php?t=495
Mine got really bad. From the time I called the dealer to make an appointment until the time I brought it in, the HID went out (probably because it got wet). The ended up replacing the whole assembly, the bulb, the igniter etc... But it all turned out well.
Did they do it for free?
Old Nov 25, 2006 | 08:53 PM
  #57
jiggaman's Avatar
yeah so this problem keeps coming back whenever the temp outside changes from warm to cold at night. what a pain in the ass. i've checked all the seals where the wires go and everything looks fine. i can't imagine that both brand new jdm headlights are faulty. its almost like there should be some sort of vent because once i break the seals where the wires go the condensation quickly disappears. when they are sealed up though it seems like the moisture has nowhere to go...
i'm at a loss and this is starting to piss me off.
paying 600.00 for another pair of headlights seems insane when i might end up with the same problem again.
Old Dec 1, 2006 | 03:52 PM
  #58
TSX_NYC's Avatar
I just noticed condensation in my passenger side light uggg. Is it a coincidence that my left side fog light also blew out? I picked up a paid of yellow bulbs from ebay about 6 months ago. Anyways can I bring my car to any dealership to have this fixed? I got my car in Scarsdale, NY cause of the price but the dealership in Manhattan is closest to me.
Old Dec 1, 2006 | 06:35 PM
  #59
MichaelkTSX's Avatar
05' NHB TSX
Yes you can bring it to any dealership to have the headlights replaced (if you are under warranty). They have a TSB out for this. Your foglight blowing has nothing to do with the headlights. They probably blew because 1)cheap bulbs 2)bad install (never touch the bulb with your oily hands else the excessive heat will blow it 3)god doesn't love your foglights.
Old Dec 4, 2006 | 01:59 PM
  #60
Tampa TSX Girl's Avatar
I had condensation in one of my headlights, too. The dealership replaced the entire headlight for FREE with no problem!
Old Dec 11, 2006 | 09:32 PM
  #61
TSX_NYC's Avatar
Took my car to Acura of Manhattan this morning. I told them about the condensation in my headlights. Even though it was longer there. I left the dealership and an hour and half later my oil change was done and they replaced the entire headlight for me. The only problem is when I switch on my right turn signal it blinks at twice the speed. I called them up and they say they know what the problem is and to bring it back in. Free parking in midtown! WOO HOO.
Old Jan 5, 2007 | 10:27 PM
  #62
TexasTSX's Avatar
5th Gear
One of mine fogged up this week and it killed my low beam. The dealership fixed it today with no questions asked. I just hope this doesn't keep happening.
Old Jan 6, 2007 | 02:48 PM
  #63
PJS's Avatar
PJS
Just had mine confirmed. That and an AC compressor - and the AC rad has been done as well.
All well after warranty too. So, major kudos to Honda UK for me.
Hope Acura does likewise for anyone found to be in a similar situation.
Old Jan 30, 2007 | 11:53 PM
  #64
chicadorada's Avatar
Unhappy
I have the same problem! I better take mine in then...mine has it in the passenger side...but the bad thing is that it's not under warranty, I wonder if they'll charge me for fixing it.
Old Mar 5, 2007 | 10:37 AM
  #65
iglen's Avatar
Let me know what they charge you (if they charge you at all) for not being under warranty. My passenger head light is having the same problem with moisture, to the point where the headlight burnt out.
Old Mar 7, 2007 | 12:34 AM
  #66
they wanted to charge me 1300.00 just for that one headlight...so I actually decided to replace both of my headlights with some aftermarket ones...it was less expensive and they look better
O, and I'm not going back to that dealership.
Old Mar 8, 2007 | 12:58 AM
  #67
iglen's Avatar
How did you find the installation? Do you think the condensation would damage the HID ballast?
Old Mar 28, 2007 | 12:46 PM
  #68
Bunny2Cute's Avatar
7th Gear
Question tsx 05
Just called ACURA regarding a different recall only to find out that headlights were recalled as well. My right side is currently fogged up so I was going to bring it in anway. HOpe it's not a long process..
Old Mar 29, 2007 | 12:55 AM
  #69
iglen's Avatar
Interesting! Is your car still covered by warranty? ...or would it matter if this headlight issue is a general recall?
Old Apr 2, 2007 | 05:12 PM
  #70
rifleman's Avatar
Got the recall notice today for my '04. Was told the new clip installation is a quick job, but that if there was condensation they'd have to order the headlight etc for a much longer job. Forgot to tell the nice phone lady I've seen traces of condensation inside the driver's side lense from time to time but lights are functioning fine. suppose I'll have to fill in the details when I show up in two weeks. (Hard to believe the service depts wouldn't have new lights in stock in view of the recall.)
Old Apr 2, 2007 | 05:42 PM
  #71
jlukja's Avatar
Here is the TSB for it
Old Apr 2, 2007 | 08:22 PM
  #72
if only I had waited just a couple months....o well, my JDM one's look nice
Old Apr 2, 2007 | 10:13 PM
  #73
goodtime420's Avatar
Whats the speed limit ?
Well I just received a letter from Acura today in the mail telling
me to bring in my car to the dealer that all 2004-2005 models have that
problem with the headlights and that they will be replacing them free of charge
Old Apr 3, 2007 | 05:09 AM
  #74
moda_way's Avatar
Ditto, got mine yesterday as well.
Old Apr 3, 2007 | 07:16 AM
  #75
LoveMyTL-S's Avatar
Got mine as well. Glad Acura has recognised this problem and is taking care of it.
Old Apr 3, 2007 | 07:32 AM
  #76
LuvMyTSX's Avatar
Where's mine?
Hopefully coming soon
Old Apr 3, 2007 | 07:59 AM
  #77
dom's Avatar
dom
First the radio and now this. What is with Acura stepping up its customer service.
Old Apr 3, 2007 | 08:10 AM
  #78
JTso's Avatar
Does the letter state that they are replacing them no matter what, or only if there is a problem? The TSB indicates replace only when water is detected inside the headlight.
Old Apr 3, 2007 | 08:12 AM
  #79
LuvMyTSX's Avatar
I remember someone in another thread saying they're going to put something on the light to keep the hood from rubbing on it. I assume they'll replace the headlight if condensation gets in it again though.
Old Apr 3, 2007 | 09:17 AM
  #80
wickedk24's Avatar
Oh well it's
Got mine too
