Check emission system light
Old Jan 29, 2008 | 02:12 PM
dinodaitalian's Avatar
9th Gear
Hi guys, last week the check emission system light came on in my 06 TSX with 35000 miles. Today, I took it to acura and they told me that the reason the light is on is due to my K&N cold air intake. Is this possible? What do you guys think? Thanks.
Old Jan 29, 2008 | 02:39 PM
curls's Avatar
Someone stole "My Garage"
Doubtful but possible.
Did they give you the code value that it's throwing? If not, check it at Autozone or many parts places like that -- they'll pull the code for free. that code will pinpoint the component (with good accuracy) that's causing the fault. Then, diagnose from there.
Old Jan 29, 2008 | 04:27 PM
9th Gear
Yes they did provide the codes which I will post later...they charged me $120 just for diagnostics since the problem is caused by an aftermarket part.
Old Jan 29, 2008 | 04:41 PM
PACman's Avatar
^^Damn, $120 just to get a code? Next time, Autozone or a friend who has an OBDII scan tool.
BTW, I have a K&N Typhoon and have been running it for 70,000miles....no codes! Is your CAI installed right?
Old Jan 29, 2008 | 05:02 PM
JediMindTricks's Avatar
What Would Don Draper Do?
i had the emission light go off once because i didn't tighten the gas cap enough.
i think the manual says that the light will go off within 3 days after the gas cap is tightened. and sure enough, it did go away on the third day.
Old Jan 29, 2008 | 05:15 PM
9th Gear
I did check the gas cap last week and it still has not gonna off. I've had my typhoon intake in for almost 2 years and no problems. Im gonna convert it to short ram this weekend and see what happens.
Old Jan 29, 2008 | 05:29 PM
PACman's Avatar
Post the code when you get the chance.
Old Jan 29, 2008 | 08:19 PM
9th Gear
P2a00
P1172
Old Jan 29, 2008 | 10:40 PM
llwtsx's Avatar
P0133, P1172 ('05-07 models), P1157, P2195, P2238, P2252, P2A00: Air fuel ratio (A/F) sensor (Sensor 1)
and also:
P2A00 Air/Fuel Ratio (A/F) Sensor (Sensor 1) Range/Performance Problem
Old Jan 29, 2008 | 10:49 PM
PACman's Avatar
Originally Posted by dinodaitalian
P2a00
P1172
Looking at http://www.hondacarforum.com/honda-3...tic-codes.html , sounds like your primary O2 sensor (air/fuel ratio sensor). Other members should chime in on this to confirm. Any how, the sensor to replace is about $213 #36531-RBB-003 ; but this is an emissions defect and should be covered under emissions warranty, which you're well within.
Your K&N isn't the reason.
Old Jan 30, 2008 | 07:49 AM
curls's Avatar
If it's the primary O2 sensor, it's not a cheap part. Advice to you would be to put the stock intake back on, drive to another dealer, and get the O2 sensor replaced under warranty.
I think it's only part of the 3yr comprehensive warranty though, NOT the 8yr emissions warranty. Actually I'm quite sure of that, since I had to replace the O2 sensor on my car last year -- the manual and the dealership both stated that the sensors aren't the full 8yr warranty, only the catalytic covnerter, and other major emissions components that aren't electrical.
The labour is simple (mere minutes) but it's the part that's pricey.
Old Jan 30, 2008 | 09:11 AM
9th Gear
I asked the service associate if anything was wrong with my O2 sensors when I picked up my car and he told me they were fine...do you think he was lieing to me? They said the reason the light came on was due to too much air going into the engine.
Old Jan 30, 2008 | 09:42 AM
LukeaTron's Avatar
... too much air going into the engine.
I suggest you whip out your junk and give that moron a nice mushroom bruise across his face.
Then take your car somewhere that the techs aren't legally retarded wards of the state.
Old Jan 30, 2008 | 10:36 AM
9th Gear
yea i might have to do that... thanks for all your help guys.
Old Jan 30, 2008 | 10:50 AM
curls's Avatar
LMFAO!!
And yeah that tech is a complete moron.
Old Jan 30, 2008 | 11:23 AM
PACman's Avatar
About 1 1/2yrs ago, I had a CEL...code P04XX (can't remember exactly since it was a while back). Took it in the dealer to get it checked out, told me they couldn't find anything wrong. They said they didn't think it was my CAI, cleared the code, and told me if it happened again, to come back (no charge on this visit). I did go back, and another SA was gonna charge me $ just to read the code, so I said screw it and bought myself a scan tool.
After posting here about my problem, which BTW curls, amongst others, helped me out, it was the air/fuel ratio sensor that was the problem. Got the part and changed it out myself - 30min job. Jacking up the car and going underneath took more time than replacing the part.
More often than not, I think our forum members know more about our cars than the Acura tech.
Old Jan 30, 2008 | 09:39 PM
9th Gear
I disconnected my battery and the check engine light went away...if it doesn't come back on does that mean the problem isnt there? I called the dealer today and they said they were positive there was nothing wrong with my o2 sensors.
Old Feb 9, 2008 | 03:06 PM
9th Gear
Does anyone know if the hondata ecu update will fix my problem?
Old May 15, 2020 | 09:03 PM
crystalnlybron Paige's Avatar
Wow...
they are not supposed to charge you for telling you what is wrong with your vehicle...that is just crazy...i would ask for my money back...i have a friend that works at auto zone and the only time they charge is when you purchase somethinh...
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
SpraykwoN
ILX
Sep 23, 2015 11:44 AM
chrisr
5G TLX Problems & Fixes
Aug 31, 2015 08:24 PM
