Cel: P1009
Old Jul 17, 2009 | 04:44 PM
IDOSEO's Avatar
Cel: P1009
Just threw this code today, has to do with Manf Ctrl air/fuel measurement? Could someone help identify the problem?
Old Jul 17, 2009 | 05:06 PM
IDOSEO's Avatar
Here's what I found, now what could be the cause or what needs to be replaced! P10XX Fuel and Air Metering and Auxiliary Emission Controls Hmmm maybe an oil change? detecting that that there isn't enough oil to engage veetac lol Hmm I don't think I was in Veeeetac when this came on.
Old Jul 17, 2009 | 06:40 PM
northbridge's Avatar
on to a CRZ
if your oil was low i believe the oil light on your dash would come on... i've never seen that code so i have no idea how to fix it specifically. hope you find your solution.
Old Jul 17, 2009 | 08:41 PM
unity's Avatar
If your oil is low this can easily be checked using the oil dipstick. Also if your oil is a bit low your engine may sound and feel rougher than usual.
Old Jul 18, 2009 | 03:32 PM
IDOSEO's Avatar
Yeah I'm at 5% before my oil change so I dont understand why this car burns so much freaking oil.
Old Jul 19, 2009 | 04:43 PM
Miamicarfan's Avatar
IDOSEO:
What year is your TSX and how much mileage does it have?
Old Jul 20, 2009 | 04:25 PM
IDOSEO's Avatar
Originally Posted by Miamicarfan
IDOSEO:
It's an 06 manual with about 55k on it.
Old Jul 20, 2009 | 04:31 PM
IDOSEO:
I am going to try to address your oil burning issues but I need to know if you bought car new or used. If you bought car used, how many miles did the car have on odometer?
Old Jul 20, 2009 | 04:36 PM
IDOSEO's Avatar
bought it one year ago with 19500 on the odo bought it with a 100k 10 year warranty through a trustworthy Nissan dealership. I dont know if this has to do with anything, but it had some kind of permanent marking on the engine cover. If you were looking at the engine it'd be on the upper left and had (i think) a 5 digit code, dunno if they replaced the engine or what happened, I went over to the dealership and had a history report of everything done to the car (it was right across the street) and nothing showed up besides oil changes. So I'm kind of puzzled. PM me lets not get off topic with this thread.
Old Apr 24, 2011 | 11:30 AM
dmckowen3's Avatar
Is there a follow up to the code? My wife's car popped this 2 days ago and I can find nothing.
Old Apr 25, 2011 | 08:30 PM
RA032025's Avatar
in the 24th and a half...
OK, CEL code P1009 is "VTC Advance Malfunction"
Troubleshooting...since you don't have the HDS to reset or check with, the following are the checks in Honda's list:
Remove power steering pump and auto tensioner, remove VTC strainer and check for clogging.
Test VTC oil control solenoid valve.
Inspect VTC actuator.
Check VTC system oil passages.
Say five Hail Marys and start again...
I can post the steps...but you'll need to be pretty comfortable working under the hood. If an oil top-up doesn't do it, you'll probably want a pro to check it out.
As for oil, TSX's burn (on average) 1/2 to 1 quart per 5000 miles.
Old Apr 5, 2012 | 01:58 AM
DDTsx06's Avatar
SOunds crazy but i had this issue, i poured a can of SEAfoam right into the oil drove it for 3 days an changed my oil, Problem solved!!! =)
jmty02
Sep 3, 2014 07:31 AM
737 Jock
1G RDX Problems & Fixes
Dec 16, 2010 06:31 AM
mau108
1G RDX DIY & FAQ
Oct 27, 2010 03:41 PM
Samdog-1
1G RDX (2007-2012)
51
Apr 15, 2010 08:56 PM
mau108
Jan 13, 2009 06:53 PM
