Car tilted left
Old Mar 22, 2006 | 12:55 PM
str8 tsx's Avatar
Car tilted left
Anyone elses TSX tilt to the left? I'm thinking it's the suspension. I took it to the dealership and they replied, "it's normal and that most cars lean either left or right". They measured both sides and said it was different by 1/4" which is not enough to warrant an issue. Thoughts, ideas? Thanks in advance!
Note: ground is flat and all tire pressures have been checked to ensure proper inflation.
Old Mar 22, 2006 | 01:44 PM
hondatypes's Avatar
dam that car has problems..unless u took the picture tilted
Old Mar 22, 2006 | 02:47 PM
micvog's Avatar
That looks like much more than 1/4"!
Old Mar 22, 2006 | 02:52 PM
Beoshingus's Avatar
Overlord
You're not like 500 lbs or anything like that, right? J/K
Old Mar 22, 2006 | 03:11 PM
Viking's Avatar
Quattro in.....
I would go to another dealership and have it checked out.
That first dealership you went to, did you get their explanation in writing, cause that doesn't sound right at all.
Old Mar 22, 2006 | 03:17 PM
JTso's Avatar
Most cars are not perfectly balanced from left and right. It's not unusual for one side to be higher but shouldn't be execessively higher. I have taken one of my other cars to the dealer and they said it's normal and won't do anything about it. I even swapped the rear shock/spring assembly with the same result.
Btw, I notice it's always the rear right corner that is higher.
Old Mar 23, 2006 | 08:26 AM
LoveMyTL-S's Avatar
Is it left side too low or right side too high?
Old Mar 23, 2006 | 09:39 AM
moda_way's Avatar
It looks like the picture to me. BTW, most garage floors are tilted for drainage... one way or another. Only true way to see if the car is balanced is to put a scale under each wheel, but then you sitting in it changes it too.
Old Mar 23, 2006 | 10:57 PM
EuRTSX's Avatar
Definitely looks like the picture =/ But then again I could always be wrong o_O
Old Mar 23, 2006 | 11:49 PM
TSX420J's Avatar
CarbonGreyPearlEbony
looks like your car didnt have its v8 today...
nah, but for real get it checked out by someone else because that doesnt look
normal.
Old Mar 24, 2006 | 03:54 AM
Alin10123's Avatar
Seeing if the floor is level is easy. Just take a level and put it flat on the foor one way, then rotate 90 degrees, and check again.
Even with the floor being compensated for, it still shouldn't be blatently obvious that the car is uneven. What you could try to do is measure it yourself. Just measure from the floor up to the bottom of the fender. Do it on all 4 corners and see if it matches up from left to right. That way you'll know if it's 1/4 inches or if the dealer was bsing you and it was really 3 inches of difference.
Old Mar 24, 2006 | 06:05 AM
aaronng's Avatar
Driver/Detailer
All of the AUDM Accord Euros on stock suspension are higher on one side by 10mm. That's way more than your 1/4". Probably the TSX is the same?
Old Mar 25, 2006 | 12:03 AM
Alin10123's Avatar
10mm woudln't be noticeable in the pic. That's like the width of not even a finger. It's obviously way more than 10mm.
Feb 25, 2020 09:57 AM
lland
Oct 4, 2015 04:47 PM
jordanboi
Sep 5, 2015 01:33 AM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
