car shaking
Old Feb 2, 2005 | 11:01 AM
iceboy1's Avatar
car shaking
hi, just last week, i noticed that my car shakes and vibrates consistently while i was driving on highway or road. wondering why? the car has only about 800km. it seems to be like tire or wheel issue. i got headaches after i drove home that night due to all the shakes after got off the highway. and it feels fine the next day i drove the car. why does it happen? anyone has the same experience?
Old Feb 2, 2005 | 11:33 AM
GIBSON6594's Avatar
My Garage
Bad Gas?
I meant gasoline bye the way.
Old Feb 2, 2005 | 11:36 AM
say what?'s Avatar
does it only happen when you go over about 90 km/h???
possibly snow in the rims... happened to me...
just clean out the snow and should be good as new...
Old Feb 2, 2005 | 12:24 PM
RadYOacTVe's Avatar
If no snow then maybe one of the wheels is way out of balance.
Old Feb 2, 2005 | 01:59 PM
iceboy1's Avatar
yeah, probably, there's quite some snow on the street on that day near my place. but i am not sure if i got snows in the rim or not. but it seems like it's probably the case. the car runs fine the next day i drove it.
Old Feb 2, 2005 | 02:47 PM
CSpaR's Avatar
Sounds like you got mudd in yur tires....My Cousin Vinny. lol
Old Feb 17, 2005 | 07:53 PM
Bizzenn's Avatar
Car shaking
i had the same problem. The tires have flat spots when there new. After 1500 miles the shaking will be gone
Old Feb 17, 2005 | 08:03 PM
Dan Martin's Avatar
Photography Nerd
Haven't heard of that before.
Old Feb 17, 2005 | 08:22 PM
Tsx536's Avatar
Rep'n Taxbrain.com
^^ Me either
Did the dealer tell you this?
Old Feb 17, 2005 | 08:25 PM
elduderino's Avatar
VP Electricity
If your new tires have flat spots, it's cause the pre-delivery inspection guys locked up your tires: )
I suspect a wheel balancing weight fell off?
Old Feb 17, 2005 | 09:54 PM
JeffTSX's Avatar
Subie Tech
Bring it back to your dealer since it's still under warranty and have them check it. The wheels probably needs to be rebalanced!!! If that's the case than you should bitch at them how you paid for PDI but it doesn't seem like it was done at all.
Old Feb 21, 2005 | 09:38 AM
maddmax005's Avatar
4th Gear
Unhappy wheel/tire vibration
hi
for sure the cases are many..........
what i can say from practical experience is the factory MICHELIN rubber is not the greatest(just my own opinion). the design uses alot of nylon,and yes,will "flat spot" simply from the car sitting way too long.
this usually works it's way out the more you drive.
as well,dealer's doing really poor PDI'S is a verified issue with ACURA.
i picked my car up,the washer fluid was empty(no big deal),shipping plastic here and there, etc...... and the tires were all set at 42 psi (note: tire pressures are set high at the factory to avoid flat spotting)
nothing like paying for a PDI done by the invisible lot guy!!!!
cm
Old Feb 21, 2005 | 10:24 AM
McGriddle's Avatar
Mmmm... tasty.
If it seems abnormal... bring it to your dealer just to be sure it's nothing serious.
Old Feb 21, 2005 | 12:26 PM
kurt_bradley's Avatar
Um, no, they don't. Keep that kind of posting up, and I'll take away your talking priviledges for the day.
The tires are set at high PSI (over 40 instead of 32 front/30rear) for transit purposes and to prevent flat spotting. This person probably has tire imbalances unless the tire pressures are seriously low.
Go to your dealer, have them test drive it, and let them figure it out. This is an easy one.
Old Feb 21, 2005 | 09:59 PM
JeffTSX's Avatar
Subie Tech
And tell them to give you 4 new tires.
Old Mar 1, 2005 | 09:16 AM
gcolby03's Avatar
TSX Owner
We just got 8 inches of snow here overnight, and mine started to do the same thing: significant shaking and vibrating at highway speeds. The funny thing is it hasn't happened before following earlier snowstorms. I am hoping it is only snow related and will go away soon on its own or with a little bit of manual snow search-and-removal.
Old Mar 1, 2005 | 09:24 AM
bigwilliestyle's Avatar
Remove snow from wheel wells as much as possible. It can get stuck in the rims which is trickier. No more snow, no more shake.
Old Apr 15, 2005 | 02:23 PM
Alin10123's Avatar
If you get snow in there that's stubborn, take a hose and hose it down.
J/K...
Dont do that, it'll freeze up and become ice.
peti1212
ILX
22
Jan 5, 2022 05:14 PM
foxriderar77
Nov 19, 2020 10:17 AM
Feb 25, 2020 09:57 AM
kuzdu
Sep 10, 2015 08:42 PM
jordanboi
Sep 5, 2015 01:33 AM
